01-26-2021, 10:15 AM | #1 |
Trying not to panic. Chunk in oil.
Newly built 292 motor. Engine builder did initial break in and oil change. I just performed a 500 mile oil change and found a chunk on the end of my magnetic drain plug.
Any ideas what it is? Should I be crying? |
01-26-2021, 10:23 AM | #2 |
Re: Trying not to panic. Chunk in oil.
Wow, that sure would make me nervous...no idea what it is.
01-26-2021, 10:48 AM | #3 |
Take the piece to the engine builder,and let him figure out what to do,he built it should fix it!!
01-26-2021, 11:16 AM | #4 |
Take off valve covers at least and see if all the keepers are in the springs.
:dunno: |
01-26-2021, 11:22 AM | #5 |
How does it run, good oil pressure? I agree with taking the piece to the builder
01-26-2021, 11:25 AM | #6 | |
As far as running goes it has been running and driving great. Strong with plenty of power. This morning on the way to work I had a miss that went away after it heated up, but other than that its been running well. Oil pressure is strong! |
01-26-2021, 11:27 AM | #7 |
Post Whore
Only one piece with no other pieces or filings? If so it may just be something that got missed in the cleaning process. If you had other pieces, or a bunch of metal filings I would definitely look at dropping the oil pan at a minimum. For more piece of mind you could cut the oil filter apart and inspect the pleats for metal.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-26-2021, 11:28 AM | #8 | |
01-26-2021, 11:29 AM | #9 |
Moderator
I'll +1 on pulling valve cover to check to missing valve keepers...
01-26-2021, 11:30 AM | #10 |
Part does look like it was bounced around a bit. I think a valve keeper would have just washed down and stuck to the magnet without getting damaged. I'd pull the valve cover and have a look just to be sure of at least that
01-26-2021, 11:37 AM | #11 | |
Post Whore
GOOD LUCK!
01-26-2021, 11:41 AM | #12 |
Proprietor of Dale's Corner
Another pull the valve cover. A little peace of mind couldn't hurt. A dropped valve would hurt.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
01-26-2021, 12:15 PM | #13 |
Can you tell if it is cast iron?
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
01-26-2021, 01:11 PM | #14 |
Looking at the picture several times I agree it looks most like a valve keeper that got munched probably when it worked its way out
Have you pulled the valve cover off yet to inspect if all the keepers are in place ? |
01-26-2021, 05:42 PM | #15 |
Thanks all!
I pulled the valve cover and checked (image attached) all keepers are present and accounted for. This is not that. If I had to guess the chunk was cast. My running theory is that it might be the outside corner of a connecting rod cap. |
01-26-2021, 06:01 PM | #16 |
Moderator
Nice rockers.
Inspection camera up the drain hole to check the rods? |
01-26-2021, 10:12 PM | #17 |
While you are looking inside the oil pan with a bore scope, I would pull the spark plugs and look at the cylinders and valves. Again for piece of mind.
01-26-2021, 11:11 PM | #18 |
Man! I hate 292 horror stories.
01-26-2021, 11:33 PM | #19 |
X2, the more peace of mind you can find the better.
01-27-2021, 10:58 AM | #20 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-27-2021, 12:38 PM | #21 |
I'm going to camp solidly on the chunk-is-foreign-to-that-engine side of this mystery! Happy motoring... -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
01-27-2021, 02:43 PM | #22 | |
I've seen some junk come out of fresh blocks that just came from the machine shop. It's not like they are "clean rooms". Hopefully that's all it is...junk from sloppy machine work. At least your mag-plug did its job!
01-27-2021, 03:01 PM | #23 |
Looks like some serious money and effort went into that engine build. I see the intake headbolt bosses were milled out too. And a nice intake. I’d be nervous about that chunk also. I’d probably drop the pan and do a really hard bottom end inspection. Then if all looks good, do a compression check before I fired it up again.
01-27-2021, 03:07 PM | #24 |
It really looks like a munched valve keeper to me. So, given you verified none are missing from this engine the little part is likely just FOD left in the engine from the machine shop.
In a couple weeks/months you won't give a rats-a.... Enjoy your truck!
1971 SWB step side: Original NM Forestry and then NM Fire truck |
01-27-2021, 03:23 PM | #25 |
Ok, I will admit it...I have been known to loose a valve spring keeper or some other small object when working on the topside. Unless I drop something down the intake (been there done that), I don't worry too much about it. I just assume it will work its way down and either come out with next oil change or stay harmlessly in the pan. Never has this caused an engine issue.
