Old 01-27-2021, 08:23 PM   #1
78chevstepside
78chevstepside's Avatar
Tilt column pivot ball
My tilt was too loose and broke the actuator . Getting ready to reassemble. The ball was jambed and now its apart . Cant figure put how to put back together . Ideas ?
1978 c10 stepside 4/6 drop 350 vortec crate 2011 camaro ss2 6.2 automatic 2017 tahoe lt 2002 silverado lt 1500 5.3 automatic. 1981 el camino
78chevstepside is offline   Reply With Quote
Old 01-28-2021, 10:53 AM   #2
RodnRudy
RodnRudy's Avatar
Re: Tilt column pivot ball
Try U Tube, I watched a video a awhile back about disassembling and reassembling a tilt wheel column. That pivot ball part was tricky.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 01-29-2021, 08:17 PM   #3
78chevstepside
Watched lots of videos . I found a good one that covered my issue . They had the same problem . Install at 90 degrees found that difficult . I removed the column from the truck . I found a another tilt column at you- pull - it 115 dollars with the intermediate shaft .when i added the tilt i used one from a heavy spline shaft . One could not disconnect and lift the shaft to 90 degrees . This one needed work also . Had trouble getting the key assemblly out because someone broke the lock . Lots wd-40 took care of that . The 3 srcews that were in there since. 1977 were troublesome . Ended up grinding a screwdriver flat and adding vice grips for more torque . Now i have 4 steering columns . 1 three speed , one automatic non tilt , one balless tilt and the latest .
Old 01-30-2021, 07:56 AM   #4
That took some ballz
