12-19-2003, 03:24 AM | #1 |
A/c Compressor Mounts
Can someone post some pictures of the a/c brackets for a small block in a 72 pick up. I just put headers in my truck and my brackets are totally different than the ones in the instructions.I also looked in a couple of catalogs that I have and they are the same as th instructions that came with the headers. My bracket mounts on the first two exhaust manifold bolts the first two intake bolts and the upper water pump bolt on the passenger side.could this be a bracket from a later model truck? This truck has factory a/c. Thanks for any help you can give.
72LONGHORN 350 CI TURBO 400 A/C P/S P/B HEAVY DUTY SPRINGS ALL THE BELLS AND WHISTLES. TUCSON,AZ. 2005 4X4 DODGE RAM 1500 "HEMI"LARAMIE 1961 OLDS DYNAMIC 88 394 4BBL UNDER CONST. |
12-19-2003, 08:11 AM | #2 |
Don't say "Oops!", Doctor
That sounds exactly like my A/C bracket. Mine's a 68 with factory A/C. Sorry, don't have any pics, though.
'Mutt 1968 CST LWB: R.I.P. 1967 Chevelle: TPI 454 beast 1967 C10 SWB: Claimed when Bumpster didn't put it on his list |
12-19-2003, 10:44 AM | #3 |
Self-proclaimed LED man
Here ya go, heres the pic you requested.
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once Norwood Survivor |
12-20-2003, 09:48 PM | #4 |
Was there two styles of brackets for these mine is basically two brackets one is I described earlier with a u bracket bolted to it . If anybody knows is their a header bracket for this type of a/c bracket? Thanks for the picture.
12-20-2003, 11:17 PM | #5 |
Standard trucks have the heater hose running into the water pump. That u bracket holds the heater hose away from the fan. If you look that u bracket is just big enough for a heater hose. Ill post a pic if i can find one.
