Old 12-19-2003, 03:41 AM   #1
cranknut67
cranknut67's Avatar
Supercharger Help
I finally found a B&M supercharger, and was wondering if anybody knows about timing issues that I should know about ?
I am going to be using a mallory comp 9000 unilite - currently I have not seen a way to get the timing controller ( MSD ) that I have to work with the 6al and the mallory dist.
I will be running the stock pulley (7 lbs of boost) with 8.5 - 9.0:1 compression - I want to keep the static compression down to 12 if possible.. and the cam - 272 crane w.454 lift ( advertised duration ) will this be ok to run with it - just afrais that I will screw this up and be rideless because I missed an obscure fact..
cranknut67 is offline   Reply With Quote
Old 12-19-2003, 11:15 AM   #2
PR454SS
PR454SS's Avatar
I think I remember reading on the MSD website or in the directions with my MSD box about how to hook up to different distributors, you may want to check there. I do know that with a supercharger you'll need to watch the boost carefully to avoid detonation/preignition as the boost climbs you'll need to back off the timing. Here is a couple of ignition setups from a Street Supercharging manual: 10 degrees dist. advance in by 3000 rpm with 18 degrees initial lead for a total of 38 degrees for the street.
Another says:to slow the dist. advance through the use of stiff advance springs and have all the advance in by 3500-3800rpm with 12 degrees initial advance.
There is really no way to tune it before you start, also you'll probably want to go to a colder heat range spark plugs to compensate for the increased combustion temps.
Sorry for the long post, I'll bet it will be Bad A$$ when you get it done
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 12-19-2003, 11:30 AM   #3
Randy70C-10
Randy70C-10's Avatar
I run mine around 36 degrees of total advance, but the best thing that works for me is to advance it until it knocks a little then I back it off, turn off the engine and start it back up. If it sounds like the starter is having a hard time turning the engine over, then I back the timing off a little more. Fire it up and take it for a spin. If you floor the pedal and it still knocks, back it off a little more. You don't want detonation, especially with a blower motor. You'll go through head gaskets every 100 miles. Also, have you done your homework? You can't put a blower on a stock engine. Some will tell you differently.
Randy70C-10 is offline   Reply With Quote
Old 12-20-2003, 02:47 AM   #4
cranknut67
cranknut67's Avatar
the motor is not really stock:
350 ci 4 bolt main block bored .40 over w/ flat top pistons (steel) w/ a steel crank,(standard stroke ) brand new world sportsman 2 heads 1.6 - 2.02 w/complete race springs/screw in studs
roller rockers, mild cam. headers MSD 6al / MSD timing controller..
think that will be ok to run with the 177?
Old 12-20-2003, 03:05 AM   #5
Rooster's 67
Rooster's 67's Avatar
Quote:: ((I want to keep the static compression down to 12 if possible.. and the cam - 272 crane w.454 lift ( advertised duration ) will this be ok to run with it))
AHHHHhhhhh .........
NO
Sorry, do you mean that you are going to set the base motor up with a caculated compression if 12:1, If so this is very high for a blower motor. Even a small huffer like the 177.
You could go 12:1 static but you would have to go to a much larger cam than the 272 crane camshaft. in the order of 298 adv. duration or larger or much more overlap like in a special blower camshaft. And the streetablity of this setup would suffer Terribly
please elaborate.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-20-2003, 03:12 AM   #6
cduster
Why not? I was told that you could on a lower compression stock motor if you used a larger pulley on the blower to run less boost.
I have never had a blower, but would really like one so any info on this would help. Thanks, Dan
cduster is offline   Reply With Quote
Old 12-20-2003, 03:18 PM   #7
Chevy67Tk
Chevy67Tk's Avatar
cranknut67
Which timing controller are you running
I’m running an MSD9877 with the distributor locked out. I’m still experimenting a lot but the last setup is 16 initial advance with total 38 all in at 3200 rpm.
Like randy said do your homework and take your time it may cost a little more now but will pay off in the long run.
Chevy67Tk is offline   Reply With Quote
Old 12-20-2003, 04:22 PM   #8
Randy70C-10
cranknut67- Flat tops will eventually crack under any kind of boost. You need to run forged/dished pistons designed specifically for blowers and turbos. Also, you should run a milder cam with a little more duration on the exhaust side, and the heads should be ported a little on the exhaust side as well. If you have the stock harmonic balancer, you should think about getting a Fluid Damper.
Rooster- Static compression is the end result (engine compression plus blower boost) The calculated static compression ratio in my Model A is 18:1.
Here's a good pic of the engine in the Model A:
Old 12-20-2003, 04:45 PM   #9
Rooster's 67
yup went back and re-read the first post....duh
he should follow Randy70-c10's suggestions for engine build rather than mine based on the way I read it at first.
Old 12-20-2003, 05:11 PM   #10
Randy70C-10
Rooster- If it can be broke, I've broke it. Rock on!
