Old 01-29-2021, 11:12 PM   #1
thefivejs1
thefivejs1's Avatar
Help with Axle / Differential identification.
Looking for information on the differential information for this 12 bolt. We just installed a 430 hp crate motor to a TH350 Transmission and want to investigate a gear package. You opinions, experience and advice is appreciated.
thefivejs1 is offline   Reply With Quote
Old 01-30-2021, 10:40 AM   #2
BigBird05
Re: Help with Axle / Differential identification.
Look for the factory numbers on the front of the RH axle tube.
BigBird05 is offline   Reply With Quote
Old 01-30-2021, 10:46 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Here are the charts.
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
Posts #8 & 19 show the locations for some of the code stampings.
LockDoc
Leon
Old 01-31-2021, 11:39 AM   #4
Accelo
Accelo's Avatar
You need to know the installed gear ratio to identify the carrier series.
And if it's a posi or not.
Even with the stamping code it's not a guarantee it what you will have.
I would pull the cover and count the teeth and see what's there.
Truck 12 Bolt
Series 2 = 2.73 - down (smaller numerically)
Series 3 = 2.76 - 3.42
Series 4 = 3.73 - up (larger numerically)
Accelo is offline   Reply With Quote
Old 01-31-2021, 12:03 PM   #5
truckster
truckster's Avatar
Your best bet is to remove that rear cover and see what's actually in there. Unless you've owned the truck since it was new, there's a chance it's been swapped. And any rear end deserves fresh gear oil if you're going to put 430 HP into it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
