Door Locks
I've read through the old threads and can't find my answer.
Doors lock fine when the doors are open with the key and with inside push down knob. Doors closed will not lock with key or knob. New Honda door seals and doors are hung square and centered. I tried pushing and pulling on the doors while locking but no luck. Help Please Thanks |
Re: Door Locks
Maybe the latch isn’t clicking all the way?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
![]() Join Date: Dec 2013
Re: Door Locks
Lock the door before closing by pushing the inside button down and close with the outside handle button pushed in . You have to hold the button in when closing the door from outside . See if that works for you .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 01-31-2021 at 12:16 PM. |
#4 | |
The Older Generation
Re: Door Locks
That won't work on these trucks Grumpy, the button will just pop back up. OP: Only way to cure that is to move the striker out. Did you lube all of the moving parts inside the door, and the star wheel? That may help if you haven't. If you roll the window down and use a good strong flashlight you can see the door latch & lock through the opening at the back of the window. Spray that, and spray a little penetrating oil on the mechanism. If you decide to move the striker out be sure and mark around it with a fine felt tip pen and only move it about 1/16" at a time. Make sure it doesn't move up or down. LockDoc
Old member
With the door closed window down take a flash light and look inside the door through the window opening on the back of door. Work the key are the door lock and see what is happening.
Pictures of what to look for, Loc Doc posted these in another thread. If you can't see these parts moving then spray them down good and I would suggest loosening the bolts on the end of the door holding the latch in place and trying it. You may want to take it all out and make sure it's all in good working condition. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Door Locks
Thanks Doc and Andy,
I'm going to give those suggestions a try this afternoon. It's strange that the entire mechanism works great with the door open. When the door is closed it turns about half the way to the lock possition then stops. When I put them together after the paint job, I have to admit I did not know what I was doing. I referanced some drawings and photos and am pretty sure I got it all right. I also used silicone lube on it all when I was putting them together. I just need to get a good look at whats going on in there. |
#7 | |
Re: Door Locks
Sounds good. It could also be that the latches are worn bad enough that the star wheel is not rotating all the way when the door is closed. That will also cause the lock to not work. Let us know how you get along with it. LockDoc
Re: Door Locks
Can you give me a small discription of what you are calling the "Star Wheel"?
Re: Door Locks
Old member
I ended up buy new latches for mine. The doors work great now.
Re: Door Locks
Old member
#13 | |
Re: Door Locks
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#14 | |
Re: Door Locks
I was always told it was so you couldn't lock your keys in the truck. Maybe the designers thought that guys that bought trucks were dumber than the ones that bought cars.... ![]() LockDoc
#15 | |
Old member
![]() Quote:
The design is a tad different is my guess. I have always herd the same as Doc. Heck maybe we are a little different than most. ![]()
#16 |
Re: Door Locks
Well,, I tried all the above suggestions. Move d the striker out then in, even tried up and down. I finally just put them back in to starting point. Lubed everything well. I took the inside door covers off and didn't see anything strange. I even turned the star wheels to different posistions.
The latches are original, so I guess it's time to give new ones a try. |
#17 |
![]() Join Date: Apr 2016
Re: Door Locks
Perhaps it wouldn't hurt to post some pictures of your setup. Somebody may recognize something that can be corrected.
#18 |
Old member
So this got me thinking. I know my 64 SS Impala you can lock the doors by pushing down the door lock knob & pushing in on the outside door button a bit and shut the door.
So with that being said I wonder how hard it would be to modify a truck latch are if you could just swap out the whole thing for a car latch. I'm going to look into this more when I have the car and truck together to compare. Here are a few pictures to checkout until then. The first 2 are 64 Impala and the last is a 71 C 10. ![]()
#19 |
Re: Door Locks
I put those 60's car latches in my 67. They work great. They lock with the button pushed in. Quite a bit of work to make it look proper and to work without moving the lock cylinder but way nicer than the original parts. I would do this mod again.
#20 | |
Old member
![]() Quote:
#21 |
Re: Door Locks
What I did was first I lined up the door lock cylinder to the hole in the skin where it would operate properly. You will need to use the pawl from the car. I them made a template on where the mounting holes need to be. You will have to enlarge the bottom recessed mounting hole from the original latch so the latch sits flat on the inside of the door. Once you drill the holes I used the mounting screw to suck the metal to a flare so the screws countersunk. The I took a air file and filed the shape of the latch. Once that was done I located the spot on the jamb where the latch pole mounts. Made the hole square so it had some adjustment. The door remote wire and lock will need some tweeking as well but that's easy. Now the crappy part of smoothing and filling out where the old latch and catch were so it looks good. I also had to weld that little piece in my picture on the top so the button on the handle would hit when punched in.
#22 |
Re: Door Locks
Victory! I got a set of new latches from Summit and the problem is solved. Between the new latches and the Honda door seals I'm loving these doors. They close Soo much better.
#23 | |
Re: Door Locks
Good deal! Glad that cured it for you. LockDoc
#24 |
Old member
Door latches make the job so much better.
#25 |
Re: Door Locks
good info. Sub'd.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. ![]() |
