Old 02-01-2021, 11:13 AM   #1
4th Gen C-10
Junior Member
What Wheel Will Work?
I'm looking to find some cheap wheels to roll a 69 LWB around the shop. I have upgraded the front and rear brakes with the 5x5 disc kit from CPP. The center hub is around 72mm wide.
Any ideas on what I can pick up for just a little bit of $$?
Jaybo
4th Gen. C-10 Build Thread
4th Gen C-10 is offline   Reply With Quote
Old 02-01-2021, 02:39 PM   #2
jimijam00
Re: What Wheel Will Work?
Those brakes just need a 15" wheel to clear the calipers, right?
Not sure why you'd spend money on a set of junkers, only to spend more money later on a set of good wheels, but it's your cash. Maybe you have the good wheels already and don't want to get them dirty?
Hit up your local bone yard for a set of mid 80's Chevy 1/2 ton wheels. Steel wheels used for spares will work fine, and probably cheaper too.
jimijam00 is offline   Reply With Quote
Old 02-01-2021, 10:06 PM   #3
Mike C
Mike C's Avatar
Jeep JK wheels are 5x5 and cheap as heck. probably work fine for rollers if hole in center big enough.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-02-2021, 01:09 AM   #4
ChevyRacefan
ChevyRacefan's Avatar
gm astro van wheels, junkyard crawl.
ChevyRacefan is offline   Reply With Quote
Old 02-02-2021, 08:57 AM   #5
OL SKOOL
OL SKOOL's Avatar
These might work as long as no termites in your area.
OL SKOOL is offline   Reply With Quote
Old 02-02-2021, 12:22 PM   #6
sick472
sick472's Avatar
OlSkool, That's a nice looking build just to be held up by plywood wheels.
I'm guessing the wood is abandoned before the motor goes in???
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 02-02-2021, 04:22 PM   #7
OL SKOOL
OL SKOOL's Avatar
I agree not mine just a pic i had saved.
