67-72 seat help
Hello, I picked up a pretty solid seat today. Good foam, only a couple tears. Tracks are all there. What it is missing is the seat adjuster mechanism. It has the handle to adjust seat but that is all. Does anyone know if theres a drawing of this and are parts available to repair it.
Thanks ! Posted via Mobile Device |
Old member
The handle if you turn it upside down should have a hard wire going over to the passenger side that connects to a locking pin on the passenger side slider.
This thread should help. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=659974
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#3 | |
The Older Generation
Re: 67-72 seat help
Here is a picture of the parts. and a couple of how it goes together. The last two are a little blurry but I think you can make it out OK. LockDoc
![]() Join Date: May 2010
Re: 67-72 seat help
I have never compared the adjustment mechanisms used on bench seats to the mechanism on my driver's side bucket. However, I think they are basically the same design. Here is a picture with 2 closeups (courtesy of Classic Bowties) which show the bottom of a driver's side bucket. Someone please chime in if the bench seat mechanism, other than the length of the rod connecting the sides, is different.
Jim Last edited by FirstOwner69; 02-04-2021 at 03:50 AM. |
![]() Join Date: Aug 2014
Re: 67-72 seat help
Yes, those parts are available.
They are the same on the bucket and bench seats.
Az |
Re: 67-72 seat help
![]() Join Date: Jun 2005
