Old 12-19-2003, 01:59 PM   #1
Low87
been here longer than Liz
Low87's Avatar
what can it be now?
I think I've got the water out of my fuel. Now, the truck is dead again. I tried to start it after buttoning up the gas tank and the battery was dead. I put it on the charger, then had to run so I took it off. Tried it the next day, still dead. I set it on the charger today and it shows a full charge. Try to start the truck, nothing. The interior light doesn't even come on. What can be causing this, or what can I check to zero in on the problem?
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 12-19-2003, 02:13 PM   #2
Low87on20s
Live from Atlanta
Low87on20s's Avatar
I had the same problem once. I changed the positive and negative cables to the battery and have not had a problem since.
Paul
Low87on20s is offline   Reply With Quote
Old 12-19-2003, 02:22 PM   #3
gldevall
gldevall's Avatar
Is your battery hooked up?
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 12-19-2003, 02:23 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
check your connections on the cables clean em all up then try again
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-19-2003, 02:31 PM   #5
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
LMAO!! I hope this is it!! I will never let him live it down!! hahaha
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 12-19-2003, 02:33 PM   #6
LOHRTBT
LOHRTBT's Avatar
Greg...In all honesty...the batt could show a charge on the charger...did you check it with a voltmeter??? sometimes it will show right and have a dead cell. But that is probably not what it is.
Make sure that you have all your connections tight and your ground has not come undone on the frame or anything like that broh.
Have you tried the battery of of something else to see if it powers the truck?
Dont make me come to tulsa to kick your arse and fix your truck!
~Dave~
Old 12-19-2003, 03:08 PM   #7
Low87
Low87's Avatar
The battery is no more than 2 months old and has probably seen 3 days max of usage. I'll check the connections, and yes gldevall, it's hooked up.....clown! Dave, you aren't ever coming to Tulsa, so I'm not worried about it.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 12-19-2003, 03:15 PM   #8
LOHRTBT
LOHRTBT's Avatar
hahah bite me bish!!
~Dave~
Old 12-19-2003, 06:31 PM   #9
Low87
Low87's Avatar
I checked the terminals, sanded them and cleaned any buildup off. I checked the ground. I checked the water in the battery. Still it does nothing. Any more ideas?
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 12-19-2003, 06:34 PM   #10
Low87on20s
Live from Atlanta
Low87on20s's Avatar
Did you check the positive cable at the starter?
Paul
Old 12-19-2003, 06:35 PM   #11
Low87
Low87's Avatar
nope.....
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 12-19-2003, 07:02 PM   #12
Low87
Low87's Avatar
Checked it, it's attached, just a bit of oil leak sludge on it. Next?
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 12-19-2003, 07:06 PM   #13
Izzy
Trucker.
Izzy's Avatar
Dead alternator is my guess, have it checked at a parts house.
Izzy is offline   Reply With Quote
Old 12-19-2003, 07:13 PM   #14
Low87
Low87's Avatar
Wouldn't I still be able to get the dome light of headlights to come on if the alt was dead?
If it is the alt, I hope I can find my O'Reilly's lifetime warranty receipt from 5 years ago!
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 12-19-2003, 07:23 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Fuseable link? I can't remember exactly where it is, but there are a couple of fusable links that could have blown. That would account for voltage at the battery, but no where else...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-19-2003, 07:27 PM   #16
Low87
Low87's Avatar
Okay, I'm game, I'll look up in the Haynes manual for the location. I'll have to check it later though, getting cold and dark around here.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 12-19-2003, 07:47 PM   #17
Low87
Low87's Avatar
Went ahead and braved the cold. I found two in the Haynes manual, one off the positive wire from the battery and one near a junction block on the firewall. I can't find either one of them in the actual truck. All the visible wiring appears fine.
One question along Izzy's bad alt theory, the positive terminal on shows power, but the positive cable at the alternator doesn't show a light. Should it? I tried both with the key off and the key forward to accessory (no difference thought at this time).
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 12-19-2003, 07:55 PM   #18
Frank-id
Voltage checks
Battery care and feeding require some work. The cables must be removed from posts to be cleaned. There are several great tools to clean both posts and cable ends. When dealing with any battery...... a digital volt meter is your best friend. The battery must indicate at least 12.6 volts.. Using a simple test lite can show the path of voltage .. Check at the battery, check at the starter power cable, check at the fuse block..... Checking the alternator will show power is leaving battery. Some times the problem is poor ground connections.... from the battery and body grounds. Ya cannot have too many grounds. Grounds are good.....
Chevy stepper 400sb 350 turbo
Frank-id is offline   Reply With Quote
Old 12-19-2003, 08:32 PM   #19
Low87
Low87's Avatar
Dave, thanks for the call letting me know the location of the fusible link against the firewall, but that wasn't it.
Frank, I did remove the cables from the posts to clean them. I'll have to check around to see if anyone I know has a digital voltmeter I can borrow. Sunday I'll also try another of Dave's ideas and swap in another battery. I can spend more time then and get detailed inspecting going as suggested by Frank if that doesn't work.
Thanks guys.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 12-19-2003, 11:26 PM   #20
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
the electrical system is soooo simple on these trucks..
check for 12v at the battery. CHECK
check for 12v at the starter + post. CHECK
check for 12v at the junction on the firewall. CHECK
check for 12v at some of the fuses on the fuse block. CHECK
check your body + chassis grounds. CHECK
that should narrow it down to something simple.
it doesnt happen to be an optima battery does it?
mike
mike reeh is offline   Reply With Quote
Old 12-20-2003, 12:35 AM   #21
Low87
Low87's Avatar
Mike and Riptide, I'll look at both those Sunday as well. Thanks for the help!
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 12-20-2003, 12:43 AM   #22
swervin ervin
swervin ervin's Avatar
I'm thinking dead cell in the battery, if everything else checks out. I've had it happen too many times. Have you tried jumping it off or another known good battery?
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 12-20-2003, 12:53 AM   #23
Low87
Low87's Avatar
Mike, I tried it on my Dad's truck. This evening my Dad suggested testing the water in the cells with a hydrometer, which I actually have.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 12-20-2003, 01:41 AM   #24
swervin ervin
Did you try installing another known good and working battery in your truck? Have you, just for the fun of it, checked all the fuses? It is a computer truck, but I doubt a blown fuse would cause your symptoms though. I'd check them anyway. It don't cost anything.
With nothing working at all, if for sure sounds to me no power is coming from the battery to anywhere. Double check all battery cable connections and cables. Check the ground cable too.
If you take a bad battery out of the picture for sure, get a test light and start at the battery checking everything for power. Check at the starter to see if it's getting any power on that end of the cable. Check the junction block on the firewall the same way. Try it with the switch on and off. Once/if you find an area the light don't work when it's supposed to, you can backtrack from there to find the problem. Sounds simple, no?
Mike
1985 Chevy C-10
