Old 02-06-2021, 11:00 AM   #1
xs-cash
LMC rear sway bar
Has anybody here bought and installed the rear sway bar from LMC? I’m thinking about it on my stock 72 1/2ton ,with rear leafs , stock height, is it worth it ?
xs-cash is offline   Reply With Quote
Old 02-06-2021, 09:46 PM   #2
young grasshoppa
young grasshoppa's Avatar
Re: LMC rear sway bar
I just installed the one sell at Truck and Car Shop (brand is ADDCO) on my '72 5/7 drop on leafs w/ a CPP front sway bar. I noticed an immediate improvement, I wish I would have done it when I put the front on.
young grasshoppa is offline   Reply With Quote
Old 02-07-2021, 01:07 AM   #3
Accelo
Accelo's Avatar
How about some pictures of the install? They don't come with any instructions, ones that are usable anyway.
Accelo is offline   Reply With Quote
Old 02-07-2021, 01:58 AM   #4
young grasshoppa
I did not take photos throughout, just have this one final one for now. Install was pretty straight forward, requires 4 holes to be drilled.
Old 02-07-2021, 09:33 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: LMC rear sway bar
Just info for you.
If you have the front bar on the truck, look into the 'No Limit" rear shock location kit. I took my rear bar off because it wasn't needed after installing Rob's kit. The kit moves the shocks out to the ends of the trailing arms. Makes a much better feel when taking curves.
If your truck is a leaf truck then never mind!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-07-2021, 11:52 AM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
Is there enough room to remove the diff cover without dropping the stabilizer bar?
~Steven
Simi Valley, CA
Old 02-07-2021, 12:04 PM   #7
Bigdav160
Bigdav160's Avatar
I don't have any pics but I installed the same addco bar in my Suburban but in front and on top of the pinion. The bar ends in my install face forward. I had to do this because my exhaust runs down the rear frame rails (rear mounted gas tank). I had to purchase longer links (4x4) but otherwise seems to work fine.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-08-2021, 12:13 AM   #8
young grasshoppa
There's a few inches gap, getting the cover would not be a problem. It's pretty easy to move out of the way too.
Old 02-08-2021, 12:43 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
Thanks, that's good to know. I want one on mine because with the new shell and the Firestone tires, it has a little oversteer, without the trailer. If my wife was driving it, she'd panic, so I need to make it neutral. I'm already running 10 psi higher in the rear tires, per tire store recommendation.
~Steven
Simi Valley, CA
