02-06-2021, 09:18 PM | #1 |
What goes here
What goes in this hole? Its been about 15-20 years since I disassembled.
Posted via Mobile Device |
02-06-2021, 10:03 PM | #2 |
Re: What goes here
Firewall pad clip from inside?
02-06-2021, 10:05 PM | #3 |
Re: What goes here
Looks like it is usually/sometimes just a dimple in the firewall. Is yours an A/C truck? If it is, perhaps it is a provision for that.
Otherwise PO might have drilled it out and utilized it for something else since it is convenient to use. EDIT: Yes here is a thread on it, http://67-72chevytrucks.com/vboard/s...d.php?t=558005
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
02-06-2021, 10:15 PM | #4 | |
Re: What goes here
02-07-2021, 10:59 AM | #5 |
Re: What goes here
Well, called my dad and talked to him about it. He said he remembered, my grandpa kept having trouble with blower motors and they drilled the dimple to put a bolt and ground blower. Makes sense to me. I guess the mystery it solved. Thanks.
02-07-2021, 12:42 PM | #6 |
Re: What goes here
My 70 has a retaining grommet in it for the firewall insulation. You can kind of see it in these pictures. I just replaced all this during my restoration process.
02-08-2021, 10:04 PM | #7 |
Re: What goes here
I also have a plain jane heat-only truck. Mine has a firewall insulation clip in that hole also as stated above. They push in from the interior and stick through the firewall.
1972 C20 |
02-11-2021, 03:03 PM | #8 |
Re: What goes here
My best guess is the antenna wire for the radio.
02-11-2021, 07:17 PM | #9 |
Re: What goes here
O3 that’s one beautiful orange !...
71 C-20 07 Magnum RT AWD |
02-12-2021, 08:36 PM | #10 |
Re: What goes here
Thank you sir! I'm almost back on the road.
