![]() Join Date: Jul 2008
Roof/upper cab cuts
Here is the upper half from what I believe is a 72. Has good drip rails $75 a side plus shipping. Cancer rust up in front by mirror inside cab. I am keeping the soft ray glass. The gasket trim is driver quality, has dents and someone pried on the passenger side corner $40 plus shipping . Passenger side upper cab corner trim $20 shipped conus/flat rate. The rest of the roof and cab cuts are $20 and up plus shipping, depending on size.
Let me know what your interested in and I can give you more info. Also if you are buying cuts of any kind, let me know where and how you want the parts cut.
1965 c/10 swb 1969 c/10 lwb ![]() |
Re: Roof/upper cab cuts
More pics
Active Member
![]() Join Date: Jan 2013
Can you get a pictures of the rust spots?
Here’s more pics.starting at drivers side drip rail, then to passenger side and onto the front of cab and then down to the inside of the front. I circled the spot that’s hard to see in a picture but cancer rust on the inside roof panel by the mirror. Hope this helps
More pics of the front
All about them K’s
![]() Join Date: Jun 2014
I need a patch in this rough area. Mine was caved in from the bed hitting the cab and the metal is very thin and not straight in this area. I can get rough measurements of the area I need later tonight or tomorrow afternoon.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
All about them K’s
I need roughly 20” inward from the outside of the passenger side of the back of the cab, then from the back window pinch weld down (including the lower pinch weld seam) I need about roughly 7.5 inches which should put you at the top of the big recesses in the rear cab panel. I actually drew it up on the side of my truck to give a better idea.
Is this a possibility?
#8 | |
All about them K’s
No, I won’t need the drip rail, the inner panel above the tank, or the door jamb. I just need the outer skin with any and all spot welds drilled along the rear window pinch weld and the pinch weld where the rear cab skin welds to the door jamb panel if that makes sense.
Thanks!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() Last edited by 57taskforce; 02-09-2021 at 01:37 AM. |
#10 | |
