02-07-2021, 03:43 PM | #1 |
Loud air sucking noise on acceleration
When I accelerate the noise is really loud. I have the stock air cleaner, so that’s probably not it. I know my exhaust leaks here and there, but it doesn’t sound like exhaust. It idles fine too, so I don’t think it’s a vacuum leak.
Any idea what it could be?
1963 C20, small window, long bed 292, 4-speed |
02-07-2021, 04:17 PM | #2 |
Who Changed This?
Re: Loud air sucking noise on acceleration
Can you get an audio/video of it?
02-07-2021, 05:48 PM | #3 |
02-07-2021, 11:59 PM | #4 |
I wanna say check timing.
02-08-2021, 12:09 AM | #5 |
Timing seems ok, right about 4 degrees BTDC.
02-08-2021, 12:57 PM | #6 |
What engine are you running? Last time I heard something similar to your explanation it was leaking intake gaskets on my V-8
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
02-08-2021, 01:10 PM | #7 |
Inline 6, 292. One bbl carb, new from Rock Auto.
02-08-2021, 01:21 PM | #8 |
pour a little water around intake gaskets while running and see if engine misses.
02-08-2021, 01:32 PM | #9 |
I did try carburetor cleaner while it was running, nothing changed.
02-08-2021, 01:42 PM | #10 |
Pour water around the intake attached to the head.
02-08-2021, 03:55 PM | #11 |
If you have power brakes it could maybe be the check valve gizmo where the hose connects to the booster but then again, that might be more of a "throttle closed" type leak
02-08-2021, 04:03 PM | #12 |
I have the same engine and carb. I have an open element filter and the intake noise is very noticeable. I suspect you are hearing what engineers have spent years designing out of our newer cars with big plastic air boxes and convoluted intake snorkels.
02-08-2021, 04:29 PM | #13 |
I have had older vehicles and never experienced this loud of air suck.
02-08-2021, 06:29 PM | #14 |
No power brakes.
02-08-2021, 08:37 PM | #15 |
Same here, even with the stock air cleaner, I have to agree with CaseyJ
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
02-08-2021, 08:45 PM | #16 |
Who Changed This?
Has it always done it, or is it a new symptom?
02-08-2021, 08:46 PM | #17 |
fan would be my guess
02-08-2021, 11:15 PM | #18 |
I have only had this truck since April 2019, and I just got it on the road this past week. Most of the time it was up on jackstands in the garage.
I am thinking it could be an exhaust leak; I assembled the entire exhaust from pieces I had in the garage, and a few new ones. I may just take it to an exhaust shop this Saturday and see what they will charge me. I could pull the air cleaner off and drive it, see is that makes any difference. It sounds good at idle, and once it warms up it accelerates ok. I have the 4-speed, stock transmission, it shifts fine. The rear end is a 14-bolt GM, 4:10 or 4:11 gears, from my calculations. The truck seems to top-out at about 55mph, primarily cuz it sounds like I am really pushing it, at about 2k rpm (if my tach is correct). It just seems so loud going down the road, but not like exhaust noise. As it is, the muffler I have installed is one of those quiet mufflers. Brings me to another question... if its worth putting 3:42 gears in it vs a 5-speed OD trans. A ring and pinion will cost about $300, and a 5-speed is probably north of $800. I think the 3:42 will only drop my rpm by about 500rpm, if I'm not mistaken. I'll have to check some gear tables.
02-09-2021, 03:22 PM | #19 |
I have an appointment at the muffler shop; figured I would get that out of the way, then go from there.
02-09-2021, 04:27 PM | #20 |
I'm thinking you have too much back pressure in the exhaust system. 292 engines have a very restrictive exhaust system. That "quiet" muffler is causing a lot of back pressure. Have them build a system with 2 1/4 or 2 1/2 pipes & a free flow muffler.
4:11 gears are as high as thy come for that rear end. A 5 speed with o-drive would be the way to go. George |
02-09-2021, 04:50 PM | #21 | |
I’ll check with the muffler shop, see how much they’ll charge. Not even sure what it should cost.
02-10-2021, 05:12 PM | #22 |
The original rear end in the 3/4-1ton trucks 72 on back had 4:11 gears as the highest ratio available. The 73 up had 3:42 ratio.
George |
02-10-2021, 05:18 PM | #23 |
That was for the original HO52/72 rear end; I swapped mine with a later ‘73-up rear end.
02-11-2021, 07:28 PM | #24 |
Who Changed This?
I don't remember if you have an oil bath air cleaner. If so, make certain that the oil level is where it should be.
02-11-2021, 09:40 PM | #25 |
No, regular dry air filter.
