Outer skin flange to door frame repair methods
Interested in other peoples methods to clean up rust and pitting under flange. After much indecision, I have come up with this- Cut off the flange of the outer skin leaving about 1/8 inch at the bend so as not to disturb the outer skin. Grind down the rust and pitting on the now exposed door frame until about 90% of the pitting is eliminated. (I noticed that the door frame is about 14g so I think it is OK to loose a bit of this thickness). For the remaining few pits, drill them out and spot weld those spots. Grind smooth. Cut a very narrow strip of 18g and weld along the join (tack and fill) thus creating the replacement flange. (Copper rich weld through primer between the layers)
Re: Outer skin flange to door frame repair methods
Seems to be easiest thing to do in order to eliminate rust/pitting under the lapped flange. Left a small gap to be filled with seam sealer.
