Old 02-09-2021, 04:50 PM   #1
ubtripn
ubtripn's Avatar
Would a 66 Chevelle 10 bolt rear-end
Bolt up to a 68 C10 with a coil rear-end?
ubtripn is offline   Reply With Quote
Old 02-09-2021, 05:04 PM   #2
Greg58
Greg58's Avatar
Re: Would a 66 Chevelle 10 bolt rear-end
An A body rearend will have upper control arm mounts on top of the pumpkin.
It will be 5x4.75" bolt pattern. I don't think it will be an easy bolt in, but anything is possible.
Greg
________________
1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd.
2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold}
1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400
2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax.
Greg58 is offline   Reply With Quote
Old 02-09-2021, 05:49 PM   #3
notsolo
notsolo's Avatar
I know you probably want to use what you have, 90's Caprice 5 bolt 5x5 bolt pattern. They will need metric studs replaced with Asa. Width is close maybe 1 1/2" narrower. Gears on mine were 273....Parking brake cables are also different. Remove and replace spring mounts. Add trailing arm perches to correct location
notsolo is offline   Reply With Quote
