Old 02-10-2021, 12:57 PM   #1
spmtamu11
72 GMC K1500 Front Hubcap Source / Can They be Made?
Hey guys,
My truck came with the white wagon wheels when I bought it. Looking to go back with the original steel wheels and dog dish hubcaps (haven't decided between Stainless/Chrome and White version yet). Having a hard time sourcing the fronts with the hole for the 4x4 hub. Does anyone have a good source for some originals?
In the meantime I figured I would think about plan B. Has anyone tried machining out the center of non K hubcaps? Seems like it wouldn't work out, but figured I would ask the group. Surely I'm not the only one who has wondered if it would work.
TIA!
spmtamu11 is offline   Reply With Quote
Old 02-10-2021, 01:38 PM   #2
sick472
sick472's Avatar
Re: 72 GMC K1500 Front Hubcap Source / Can They be Made?
I have used a Dremel tool with a cut-off wheel and cut holes in hubcaps. Use a awl scribe to mark the circle, rough-in with the cutoff wheel and come back with die grinder and fine carbide bit to finish it up nice and round. Some sandpaper will knock the sharp edges down. It takes a steady hand and some patience. If you cut and/or grind too rapidly you run the risk of discoloring the hubcap with heat build up.
Machining them sounds risky. Once the tool cuts through the hubcap...it might want to throw the cap instead of finishing the cut. Not to mention how you would fix a rather flimsy hub cap. I'm no machinist, however. I'm sure there is a way to machine grind the hole, but your common shop may not have that equipment.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 02-10-2021, 05:51 PM   #3
landarts
landarts
There has been a few members on here that have made them before. Lots of people will cut out the center a little small then use a mandrel to bend over the inner lip. Some have made them out of wood or a metal pipe. I will see if I can find a few threads and update here.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 02-10-2021, 07:54 PM   #4
CG
BlahBlahBlah
Board member/vendor PICKMUP (Frank) has built a very nice "jig" for removing the center of the caps for use on 4x4. Im not sure what he charges to do them, maybe shoot him a PM. They look super nice.
Old 02-10-2021, 08:53 PM   #5
52napco
I don't believe anyone does the smaller caps since they are still obtainable..always some on ebay or the classifieds here
52napco is offline   Reply With Quote
Old 02-10-2021, 09:10 PM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: 72 GMC K1500 Front Hubcap Source / Can They be Made?
Looks like a 4" hole saw would do the trick nicely!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-10-2021, 09:51 PM   #7
best view
Randy does them
best view is offline   Reply With Quote
Old 02-12-2021, 11:50 AM   #8
spmtamu11
Thanks guys, I figured someone would have at least tried it. Good to know it's doable and there are folks who could help out if I get in over my head.
I'll definitely try to source them first on here and usual places (ebay, craigslist & facebook marketplace).
Originally Posted by best view View Post
Randy does them
What is Randy's display/username? TIA!
Old 02-12-2021, 01:15 PM   #9
too much stuff
Roadtrip!
too much stuff's Avatar
What is Randy's display/username? TIA![/QUOTE]
He is not a member here anymore.
I don't know of anyone punching out the 1/2 ton caps.
You could try franks in wash. (pickmup) i think is his board name
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-15-2021, 01:01 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Posting this just as a heads-up that cut examples are being offered now - at least this seller was upfront about it.
"These are very nice and clean 10.5 inch blazer or k10 hubcaps. The fronts were machined by an airplane parts machinest and are done perfectly."
https://www.ebay.com/itm/1967-1973-C...cAAOSw~kRgJrlT
Old 02-18-2021, 10:34 AM   #11
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 72 GMC K1500 Front Hubcap Source / Can They be Made?
Not mine but you may want to call are send him a message.
https://www.facebook.com/marketplace...69635219856162
