02-11-2021, 03:59 PM | #1 |
67-72 Auto Crossmember ?
I should know this but I am brain farting I just put a auto crossmember in a 2 wheel drive I am changing from manual to auto. My question is are they a front and rear to the crossmember? I swear when I look at it. It looks like it is angled toward the front of the truck. Maybe just getting old and eyes getting bad. It does have two holes on one side with brackets and nothing on the other?
02-11-2021, 04:31 PM | #2 |
Re: 67-72 Auto Crossmember ?
dont know if this helps but here is mine going back together.
69 C10 All new build with Patina Body |
02-11-2021, 06:42 PM | #3 |
I don’t think it matters but I have one here that has one hole in the back. Some of the trucks that had turbo 400 had two brackets on the back that held part of the emergency brake cable if I remember correctly.
02-11-2021, 06:44 PM | #4 |
Here ya go.
02-12-2021, 12:57 AM | #5 |
The Older Generation
I think they angle down a little toward the rear because of the angle of the engine/transmission. I don't know if this thread will help any or not because it is mainly about the difference in the TH350 and TH400 ones. http://67-72chevytrucks.com/vboard/s....php?p=2181366 LockDoc
02-15-2021, 05:27 PM | #6 |
Still plays with trucks
Both of my 67-72 T-400 trucks and my T-400 Suburban had the two rear cable guide bracket crossmembers.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
02-15-2021, 10:19 PM | #7 |
Cool, I’m not sure if I’ve ever see those cable guide brackets, on ANYof the pickups I’ve seen or worked on!
Thanks! |
