02-11-2021, 04:16 PM | #1 |
Dana gmc 1972 k2500
Hi
I have a question My k2500 72 very heavy and I need more speed Do I change Dana !?
MY Facebook ( saad_alhajri ) on Instagram
02-11-2021, 05:52 PM | #2 |
Re: Dana gmc 1972 k2500
What is the most appropriate measurement to increase the speed and reduce the pressure of the engine ?
02-11-2021, 08:42 PM | #3 |
Easiest thing is to swap an NV4500 5 speed or you could re-gear to 3.54 but you will have to buy 3 series carriers on both ends.
Spend extra money on good ring and pinions...hard to get a good pattern on cheaper gear sets. Last edited by 52napco; 02-11-2021 at 09:06 PM. |
02-12-2021, 06:17 AM | #4 |
I appreciate this big brother and I will definitely replace gears, but I didn't understand what it meant ( buy 3 series carriers on both ends ) .. !
02-12-2021, 08:41 AM | #5 | |
Carpe manana
For some reason I’m recalling that 12 bolt rear axles need a series three carrier but those are for 1/2t applications not your k2500. Can’t the D44/D60’s take 3.54 gear sets without need for carrier change? Switching to 3.54 will help your cause. Alternatively, could add a Gear Vendors overdrive unit and keep the existing gears.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-13-2021, 02:49 PM | #6 | |
02-13-2021, 03:52 PM | #7 |
As mentioned, a Gear Vendors Overdrive unit might be a better option for you, versus re-gearing both axles. Take a look at the links I've provided below. Currently, I have Gear Vendors overdrive units installed in two of my K series trucks. Both trucks have the NP205 transfer case, such as your truck, and the install is easy... compared to re-gearing both axles.
Here's an old article on installing a Gear Vendors unit... https://www.gearvendors.com/4wheel-sep99.html Here's the website for Gear Vendors... https://www.gearvendors.com/4x4gmmanual.html Here's a pic of a GV unit I installed in one of my trucks. The transfer case is a NP205, which again, is what your K2500 should have. |
02-13-2021, 04:04 PM | #8 |
Carpe manana
If I could do my K20 over I'd go GV overdrive. I don't have known part numbers to share but believe Yukon Gears (https://www.yukongear.com/) can set you up with the axle pieces you'd need for a gear swap.
02-13-2021, 05:48 PM | #9 |
I don't know how to thank you, I'm still learning here and I'm very lucky with you. Thank you
02-13-2021, 05:54 PM | #10 | |
All about them K’s
a Good Man, I agree I would go the gear vendors route, by the time you got new gears and install kits, seals etc to swap gears on both axles and got everything installed, you’d probably end up spending more than the gear vendors unit.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
