Old 02-12-2021, 02:28 PM   #1
tinman_local2
69 k20 rockwell to np205 swap
I swapped out the old t-221 for a np205. I didn't move the transmission cross member. It appears the distance from the front of the bell housing to the center of the motor mount is a little short. The mounting adapter on the 205 is 2 1/4" longer than on the 221. Are there any problems with moving the front cross member forward a couple inches. I'm down to bare frame so it won't be hard to do, just don't want to run into trouble later.
tinman_local2 is offline   Reply With Quote
Old 02-13-2021, 08:29 AM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: 69 k20 rockwell to np205 swap
I can't answer your question, but I can give you some info that might help you avert another issue. The t221 cross member is 1" shorter ( top to bottom ) than the np205 cross member. So if you use the t221 cross member with a np205 your t-case might be hitting the floor of your truck !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 02-13-2021, 05:28 PM   #3
gmc684x4
I have done this swap several time I used the complete tranny transfer case and crossmember for the swap
Which transmission did you have sm420 or sm465 ?
The 465 np205 with matching crossmemeber
It will sit back further and need new holes
420 t221 vs 465 205 combo use different drive shaft length as well I can not say about the 465 t221 combo as I have not played with that setup
gmc684x4 is offline   Reply With Quote
Old 02-13-2021, 06:36 PM   #4
tinman_local2
I've got the 465. I moved the front cross member forward. I think it will help with the transfer case interference with the cab leaving the original trans cross member where it is. Hopefully this isn't a mistake.
Old 02-14-2021, 07:59 AM   #5
CUSTOM/10
CUSTOM/10's Avatar
If the t-case does hit the floor you can get a t/c lowering kit, it's basically some spacers and longer bolts.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 02-14-2021, 04:24 PM   #6
gmc684x4
When swapping i kept motor in stock 4x4 location and used drive shafts from donar vehicle that I swapped tranny tcase from
Is your front shaft a double cardigan joint ?
Most of the diff is a 420 tranny is shorter then a 465
Moving the engine forward you will have to watch for clearance issues with the front diff pumpkin which is why the engine is in the back position
Old 02-14-2021, 07:10 PM   #7
tinman_local2
The drive shaft is the double jointed one. I've got a 4" lift, so I don't foresee any clearance issues with the differential. I'll have to have the drive shaft lengthened. The rear will need shortened.
