T-case Trans. Question
I need to know if i can just bolt a t-case adapter from a 700r4/np208 combo to a rwd 700r4 out of a z-28 or will i have mainshaft problems such as spline count or shaft length etc
i may have to put in a 700r4 (out of Z28) into my blazer which had a 700r4/208 combo originally and i still have the t-case and adapter ......... i need to know if this will work i have a th400 in the truck now and the yards around here are outrageously high for the t-case for that so if i cant find a t-case then i will use what i do have Thanks,Keith
85 K5 BLAZER 305 TH400/208 3.08 REARS NO LIFT 95 DODGE RAM 2500 MAGNUM 360 4X2 EXTEND CAB-LONG BED If you can read this, thank a teacher. If you can read this in English, thank a veteran. Last edited by INTIMIBLAZER; 12-21-2003 at 12:05 AM. |
Tail shaft may be differant, I know they are on the th350's but it should be pretty easy and cheap to swap.
2011 CCSB GMC 2500HD DMAX 73 GMC 3/4 ton 4x4 96 Chevy 1500 STD Cab Shortbed Z71 Owner of WickedWolfRC.com |
I appreciate the info but i knew that much (not being a smart a$$)
I don't know if the mainshaft coming out of the trans was longer or shorter for a RWD as opposed to a 4WD or if the mainshaft had a different spline count I have heard that these are differences on the RWD and 4WD versions of the Th350 Thank you ,Keith
85 K5 BLAZER 305 TH400/208 3.08 REARS NO LIFT 95 DODGE RAM 2500 MAGNUM 360 4X2 EXTEND CAB-LONG BED If you can read this, thank a teacher. If you can read this in English, thank a veteran. |
Steve 86 K30 4x4 6.2L Diesel\TH400\NP208 - 14bolt FF rear w/detroit locker and Dana60 front w/detroit locker- both with 4.56 gears "Runs on Mud" |
you are the man
![]() thanks a million , that's just what I needed if I cant put it back together with that ![]() ![]() ![]()
#6 | |
![]() ![]() I did it I did it :p ever notice how much i did it looks like idiot : just a thought
