Old 02-13-2021, 01:41 PM   #1
BigBird05
rims
Does anybody know if the 1999 thru 2006 Chevy 6 bolt rims will fit on a 1970 C-10?
BigBird05 is offline   Reply With Quote
Old 02-13-2021, 04:59 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: rims
The center hub opening is too small from what I have heard. The opening will have to be opened up some.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 02-13-2021, 05:52 PM   #3
truckster
truckster's Avatar
Re: rims
If it's a C10 it should have a 5 bolt pattern...
If it's a K10 the bolt pattern on both is 6x5.5, but the center opening is going to be too small, as mentioned. I found a local machine shop that could open up the center hub on some motor home wheels for me... I think it was $45 to $50 per wheel.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 02-13-2021, 06:27 PM   #4
SCOTI
SCOTI's Avatar
Re: rims
Not until 71 & disc brakes came along.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-13-2021, 08:23 PM   #5
truckster
truckster's Avatar
Re: rims
In that case, it should fit, with the proper machining. You also need to consider the length of the wheel studs. You may need to swap them out for longer ones if you're using aluminum wheels.
