Old 02-14-2021, 01:19 PM   #1
Accelo
Accelo's Avatar
Tachometer WILL **NOT** WORK W/ HEI DISTRIBUTORS
I am putting together a stock style dash with a tachometer. I would prefer the 8K Rpm limit style tach. Can anyone add information to why these tach's will not work with HEI?
Below is the provided disclaimer;
For all of you fanatics out there, we have finally reproduced an original looking tachometer to fit correctly in you original instrument cluster with only minor modifications. Tach kit includes everything needed to convert to a tach dash; tachometer, lens, printed circuit, wiring harness, & 2 piece metal housing. WILL **NOT** WORK W/ HEI DISTRIBUTORS
What I am more concerned with is if the tachometer will work with the computer output from the LS1 style computer. I see the addition of a pull down resister is required with some/all of the computer rpm connections.
Rick
Accelo is offline   Reply With Quote
Old 02-14-2021, 03:23 PM   #2
kwmech
Re: Tachometer WILL **NOT** WORK W/ HEI DISTRIBUTORS
That's a good question, every truck I've had with a tach or put a tach into did not matter whether or not it had HEI. Link to the maker
Old 02-14-2021, 03:42 PM   #3
Lee H
Lee H's Avatar
Since it's a "stock style" VS stock you can have the tach internals rebuilt with VDO internals and it will work with HEI. I had this done about 10 years ago, works well.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-14-2021, 08:06 PM   #4
heskahoka
heskahoka's Avatar
I had the same concern when I decided to put a factory looking tach in my truck along with an HEI distributor.
Here is a quick explanation of why HEI is different:
https://www.americanautowire.com/vie...c-distributor/
I ended up going with a go between interface box called TachMatch (model TM-03). It can take the signal from the HEI and converts it into the correct pulse pattern for the tach.
https://technoversions.com/TachMatch.html#itworks
I mounted the unit above the steering column behind the instrument cluster. They had great technical support too.
Works flawlessly.
On their website, it states that the unit can take a signal from the HEI or ECU; it has to correct pull-up resistor for the ECU.
Hope this helps.
-M
heskahoka is offline   Reply With Quote
Old 02-14-2021, 08:20 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Tachometer WILL **NOT** WORK W/ HEI DISTRIBUTORS
I've done several trucks with stock GM HEI and never had a problem with the truck tach's. The last one I did worked for a while but quite. I sent it off and had it fixed. I added a 5amp fuse to it per the guy that fixed it and it's been fine ever since but no filters on any of them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-14-2021, 08:37 PM   #6
Mike C
Mike C's Avatar
Where is the fuse Andy? Power line or the signal? I would assume power, but you know how assume works...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-14-2021, 09:14 PM   #7
Andy4639
Old member
Andy4639's Avatar
Yes the power wire out of the fuse block. I've never had one to quit but this one came from brothers. They made it good and said they didn't need the old one back so I sent it off and had it fixed as well.
Here is the thread to mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=803315
Old 02-17-2021, 10:25 PM   #8
StingRay
StingRay's Avatar
I ran a factory tach in my 72 with an HEI for 20 years. Why exactly is it that it is not supposed to work? Lots of people have run them just like me.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 02-18-2021, 01:32 AM   #9
LockDoc
The Older Generation
LockDoc's Avatar
I read it that he will be using an aftermarket tach. Not all of them will work with an HEI out of the box. That is what he is referring to.
LockDoc
Leon
Old 02-18-2021, 02:14 PM   #10
tdangle
tdangle's Avatar
I have a Brothers 8K tach upgrade. It's worked great with 3 different HEI distributors so far.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 02-18-2021, 02:22 PM   #11
Andy4639
Old member
Andy4639's Avatar
Are you running the 5amp fuse? Mine has been good ever since I installed the fuse. It has been the only one that was aftermarket for me. All the rest have been old factory tach's and never had a problem with them.
Old 02-18-2021, 04:27 PM   #12
Accelo
Accelo's Avatar
The consensus seems to be they will work without major issues on the HEI. Unsure why they posted the disclaimer. Covering their A** is the only thing that comes to mind.
Rick
Old 02-19-2021, 08:52 PM   #13
tdangle
tdangle's Avatar
Not yet, I keep meaning to install a fuse, but haven't yet. It's only been a couple of years now, don't want to rush into it.
Terry
Old 02-19-2021, 10:01 PM   #14
Andy4639
Old member
Andy4639's Avatar
Talking Re: Tachometer WILL **NOT** WORK W/ HEI DISTRIBUTORS
I never had either until this one.
