Old 02-14-2021, 04:14 PM   #1
BigBird05
Frame
Is the 127 inch C-10 LWB (1972 ) frame as the 127 inch Suburban (1970 ) frame.
BigBird05 is offline   Reply With Quote
Old 02-14-2021, 05:07 PM   #2
HO455
Post Whore
HO455's Avatar
Re: Frame
There are differences due to the body mounts, fuel tank mounting, and the rear horns are noticeably different. There may be more but they are escaping me at the moment.
So no they are not the same.
RIP Bob Parks.
Old 02-14-2021, 09:39 PM   #3
BigBird05
Re: Frame
Body mounts are just riveted on, but I didn't know about the rear frame horns being different. Thanks.
Old 02-15-2021, 09:25 AM   #4
HO455
Post Whore
HO455's Avatar
Re: Frame
The ends are folded for the bumper to mount.
RIP Bob Parks.
Old 02-15-2021, 10:20 AM   #5
dozerbill72
dozerbill72's Avatar
Re: Frame
The only difference in the rails them selves is the last foot or so. Burb frames are longer with the end shaped for the bumper to bolt on.With the burb frame there you can remove and reuse the rear horns and make a pickup frame work. As mentioned the body mounts just rivet on and can be swapped frame to frame.
dozerbill72 is offline   Reply With Quote
Old 02-15-2021, 01:34 PM   #6
BigBird05
Re: Frame
Thanks dozerbill72, The back half is good ( I think ). I know that the front frame horns are gone.
Old 02-15-2021, 01:35 PM   #7
BigBird05
Re: Frame
How is the gas tank area different?
Old 02-15-2021, 05:43 PM   #8
dozerbill72
Re: Frame
There are no bolt holes for the tank straps but other than that they are the same.
Old 02-15-2021, 07:53 PM   #9
BigBird05
Re: Frame
Thanks dozierbill72,You are making it easier for me to want to save this Suburban/ ambulance with all of your information. The frame was the biggest hurdle, I think. What are the MAJOR parts that you can't get for the body?
Old 02-16-2021, 10:48 AM   #10
dozerbill72
Re: Frame
Basically anything burb specific, but alot of Blazer and pick up stuff can be worked to fit. The worst is inner body structure "behind the quarters and the likes". Those areas don't have to be pretty so you can make repairs that work and then use bought patches to make her pretty. The do make quarter patches and the 3rd door rockers. Pick up inner rockers and floor patches can be made to work for the rear doors. The passenger rocker is different but a pick up is easily modified. I assume it's bran doors since it was an ambulance, they tended to hold up better than the gate and hatch. There are lots of threads on here of guys doing everything to these with some good photos and info. Good luck and have fun.
