02-15-2021, 01:13 PM | #1 |
Turbo build
I am in the midst of putting a turbo on my now LS swapped 63 C10... with that said I can find anything recommending intercooler size. That’s where I’m at right now and I’m struggling. I had a generic one leftover and it doesn’t seem like it’ll fit. Obviously I’m not the first first to do this , so hopefully someone can help
Posted via Mobile Device |
02-15-2021, 07:55 PM | #2 | |
Re: Turbo build
Check out the LS section lots of info over there on turbo builds. I added a turbo to my 65 here is the link. My intercooler is 24x12x3" . I had to cut my rad support up to fit it in. Go as big as possible on inlet/outl;et piping and intercooler. I retained my battery in factory position but was alot of fab work making my hot side manifold and fitting everything else
https://67-72chevytrucks.com/vboard/...turbo+in+my+65 Quote:
02-15-2021, 08:02 PM | #3 |
Re: Turbo build
You might try over on "The Turbo Forums". There is probably a calculator for that!
02-15-2021, 09:15 PM | #4 |
Re: Turbo build
Thanks , yeah I’ve ran into a bunch of obstacles. I’ve pieced most of it together , I ended up having to cut out my passenger fender and put a vented patch in to accommodate the WG and venting back into the exhaust housing. With all my hot side squared away I’m running into the cold side problems... I knew I either had to rebuild the radiator support or sink it into it , your idea is one I didn’t think about!
02-16-2021, 12:33 AM | #5 |
Re: Turbo build
I was able to fit a 31x12x3 behind the grill, without molesting the grill.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
02-21-2021, 07:29 AM | #6 |
Well I took advice from all sides ! Thanks
02-21-2021, 12:58 PM | #7 |
Re: Turbo build
