Old 02-17-2021, 08:27 PM   #1
hubdawg
Any flexible transmission cooler lines
Put an LS into my 72 Blazer with a rebuilt TH350 and used a Dirty Dingo crossmember. Time to hook up new stock cooler lines and there is no way possible with this set up. Anybody recommend a flexible line option.
Since I have the new pre bent and can't send back can I use a combo of braided/hardline to get around the crossmember/header trouble spot.
hubdawg is offline   Reply With Quote
Old 02-17-2021, 08:56 PM   #2
JJH Jimmy
JJH Jimmy's Avatar
Re: Any flexible transmission cooler lines
That’s exactly what I did on my Jimmy build. I used Russel Proclassic hose and flared sections of the hard line to adapt to it. There are some pictures on pages 2 and 3.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 02-23-2021, 08:37 PM   #3
hemi43
hemi43's Avatar
I used hydraulic hose and fittings. 3/8 hose with #6 ends. Do it once and you'll never have any issues. Fairly cheap too.
hemi43 is offline   Reply With Quote
Old 02-24-2021, 06:30 PM   #4
mister.freeze
mister.freeze's Avatar
I did this too. Too many hose clamps that failed or slipped and hard lines are just a pain.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 02-25-2021, 11:54 AM   #5
hemi43
hemi43's Avatar
I also use hydraulic hose for the high pressure power steering hose. The aftermarket hoses are all Chinese, and most are crap. It's just one less thing to worry about.
Old 03-10-2021, 09:11 PM   #6
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I made my own hard + soft lines that go from my trans to a stacked plate cooler.
Here's that post.
https://67-72chevytrucks.com/vboard/...smission+lines
Here's one of the soft lines I made.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
