12-19-2003, 08:59 PM | #1 |
18436572
modifing the lower control arms
I have a 4/6 drop kit and a disc brake conversion from ECE on my 70' sb fleet and i'm running 16 inch rims. The problem i'm having is the inside rim lip is rubbing the control arm. Well, i ground some of the arm away but it still rubs at almost full turn lock.
What do you guys think about notching the control arm on both sides and then boxing the arm in? Is there an aftermarket lower control arm i can buy instead that will have the clearance for my rims? I got to do something as i went in for the frontend alignment and found also that my lower ball joints were damaged upon install(it looks like the shop that did the install beat the ball joints in with a hammer) resulting in quirky steering problems. With the truck on a lift it takes alot of force just to turn the tires left or right pushing on the tire, very stiff. So i figure i'll fix 2 problems at once. |
12-20-2003, 03:43 AM | #2 |
I've trimmed all my a-arms back on trucks I've owned/lowered. The trick is to trim the lip w/o creating any sharp edges that can develop into a stress related crack.
To prevent the chance of cracks, I drill a 5/16 or 3/8 hole where I want the trimmed part to stop. Then cut the lip off from the hole to the balljoint area & grind everything smooth. I'll also trim the opposite side of the hole (towards the frame) to a 45deg angle. I've never had a problem w/just trimming the arms, but boxing them would be the best.
12-21-2003, 05:37 PM | #3 |
Project92 SWB stepside
Have you tried running a small 1/4" spacer?? This would likely take care of it?
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
12-21-2003, 09:52 PM | #4 |
While spacers might solve the problem of rubbing, keep in mind they also add to the track width. For me, the stock track width is the max that is acceptable.
12-21-2003, 11:43 PM | #5 |
18436572
With the ECE spindles, the track width is already 3/4 inch wider on each side than stock so spacers are out of the question. I'm going to check on a price to modify the a-arms. I'll keep you guys posted on the updates. If the price is good then maybe i'll get a few sets made extra to sell.
