Old 02-20-2021, 08:53 PM   #1
1774btcrew
1774btcrew's Avatar
Pictures of the difference of front tank brackets right to left
I am sure this has been covered before but I couldn't find it. I have a set of gas tank brackets and can't remember which is right or left on the fronts. My buddy needs them and his truck is in the shop right now and can't just test if they fit(truck is clear across town) I don't want them to go put them on and realize it is for the opposite side. I also heard 1973-76 were different? Any pictures and help is appreciated
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 02-20-2021, 11:48 PM   #2
kipps
Re: Pictures of the difference of front tank brackets right to left
Mine were interchangeable side to side(truck in signature). The front and back brackets were different, though.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 02-20-2021, 11:50 PM   #3
1774btcrew
1774btcrew's Avatar
Technically they will switch from side to side but the weld nuts are in a different place on the front bracket
Old 02-21-2021, 12:44 AM   #4
kipps
Could be. One of the tanks on my truck was supported by two rear brackets. It did a really odd-looking nose dive under the driver's door. I grabbed a random front bracket from a pile of squarebody parts in the junkyard to complete my set of brackets.
I don't remember details, but some of my brackets had welded-on nuts and some didn't. I welded new nuts in place on any that were missing them.
Old 02-25-2022, 09:49 PM   #5
1774btcrew
1774btcrew's Avatar
Still looking for pictures
Old 02-26-2022, 10:34 AM   #6
sick472
sick472's Avatar
This photo is from my 76 C10. The bracket on the right is the rear one and it is taller where it bolts to the frame. My set-up was mounted to the passenger side if that matters.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
