02-26-2021, 01:46 PM | #1 |
fuel line clips
someone help! why do these have a barb sticking out? does the barb just straighten as you tighten it to the frame? also, do the screws screw into the orange clips to hold it do the frame?
02-26-2021, 03:04 PM | #2 |
Re: fuel line clips
Green mount has a corresponding hole in the frame to keep it from twisting while tightening the bolt. Orange one just snaps into the hole
02-26-2021, 03:46 PM | #3 | |
Almost Satisfied
Re: fuel line clips
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
02-27-2021, 08:34 AM | #4 |
Re: fuel line clips
I just recently did these from Inline Tube. The red ones were sloppy in the holes wouldn't fit tight. I took a flat punch put it in the hanger hole insert hanger in frame and give it a good whack. It mushrooms out the end and they fit tight after that. I never used the other one still in the box.
02-27-2021, 09:00 AM | #5 |
Re: fuel line clips
I took pictures of mine at teardown. My 72 didn't use those clips at all. They weren't right for mine. All of my clips and lines were held in place by bolts and nuts.
02-27-2021, 12:58 PM | #6 |
Re: fuel line clips
Thank you everyone for the replies
