12-20-2003, 01:05 AM | #1 |
clutch install questions
Anybody have any good advice,or step by step for installing a clutch in a 4 speed 4X4 behind a small block 400
Thanks for anything you can tell me (I have never done it before) David
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
12-20-2003, 01:28 AM | #2 |
I haven't done one for a while so I will just give you a few pointers that I remember. You will have a plastic allignment tool that will fit into the clutch disc and the bearing that's on the end of the crankshaft, that will keep the disc in place while you tighten the pressure plate. Be sure to get the flywheel resurfaced, and don't get anything on the face of the flywheel, the clutch disc, or the pressure plate. It really is pretty easy. Hopefully someone else can fill in all of the holes.
For me putting the tranny back in was a 2 person job - but I did it with me and a jack - but it was a pain in the ass. Get another person to help you with that if you can. Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
12-20-2003, 01:50 AM | #3 |
Make sure when you are putting the tranny back in you put it in gear so you can turn the output shaft so you can get the input shaft lined up with the clutch.
Just a little crazy 1970 chevy full size half ton, soon to be one ton running gear, 350 turbo, 205 case, 355c.i. |
12-20-2003, 01:51 AM | #4 |
My son, my joy.
If I was doin a clutch on my truck I'd be more inclined to just pull the motor. I hate wrestling with a big tranny while on my back the whole time.
12-20-2003, 02:10 AM | #5 | |
Bloo
make sure you have a weighted flywheel made for the 400 which is externally balanced... also im not sure if you can do this or not, most 400s came with autos and therefore they didnt drill the clutch Z-bar bracket holes on the block
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
12-20-2003, 02:45 AM | #6 |
eat your wheaties!!!
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
12-20-2003, 03:36 AM | #7 |
Sisyphus was my mentor!
I bought some long bolts the same thread that hold the tranny onto the bellhousing - cut the heads off & round them on a grinder. I threaded them in & used them as a guide for the tranny & as a place to rest & turn the inputshaft to align the splines. Change as many seals as you can when you pull the tranny - its easy when its out. Put on a new clutchfork boot, get the flywheel ground, use lots of brake cleaner spray, grease the splines on the driveshaft upon re-installation & IF your rearmain seal is leaking on your motor change it now - its easier with no flywheel in the way.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
