03-01-2021, 06:15 PM | #1 |
L99 w/DOD delete - 0il pan question, please HELP!!!!
I am trying to find an oil pan for my L99 that I am removing DOD and keeping VVT.
I have read that there is a oil bypass in the DOD/VVT pans to allow bleed oil pressure to operate the DOD/VVT. If keeping the VVT only does it require a special pan? ~JH |
03-06-2021, 09:52 AM | #2 |
Re: L99 w/DOD delete - 0il pan question, please HELP!!!!
I believe only needed for DOD, but thats an interesting question. the passage in the pan can be plugged off, with a metric threaded pipe plug. so whatever pan you go with you can defeat the bypass valve. Personally i don't see why the VVT would need the bypass valve.
https://www.improvedracing.com/ls-oi...alve-plug.html
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
03-06-2021, 05:55 PM | #3 |
Can't say about the DOD but when I deleted the VVT on a 2010 L92 I used a 2002 Fbody oil pan with no issues. Might want to check the folks over on LS1tech.
