Old 03-02-2021, 11:57 PM   #1
Oldironracing
Oldironracing's Avatar
Vintage air heater control valve placement
Any ideas on where to hide the heater control valve? Can you put underneath the dash in the lines?
OLDIRONRACING
Oldironracing is offline   Reply With Quote
Old 12-05-2021, 09:35 PM   #2
Peanut74
Re: Vintage air heater control valve placement
I ran my heater lines along the top of the inner fender well behind where you put the fender bolts in. So I went ahead and mounted it where you wouldn't see it under the fender.
It really doesn't matter where you put it since it is just a valve. The intent is to cut off coolant flow so that the A/C doesn't have to work as hard to cool the cab.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 12-05-2021, 09:50 PM   #3
lutronjim
Be carefull in mounting. I found out its driectional when I had heating problems.
lutronjim is offline   Reply With Quote
