Old 12-20-2003, 01:00 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Theft Prevention
I AM REALLY TIRED OF ALL THE 4X4'S GETTING STOLEN AROUND MY TOWN.. SO I WENT DOWN TO PART'S STORE AND FOUND THIS MASTER ON/OFF SWITCH,I WAS THINK OF HIDEING IT SOMEWHERE THAT IS EASILY ACCESIBLE ON MY BLAZER... ANYONE EVER USE THIS TYPE AND HOW DID YOU HOOK IT UP??
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-20-2003, 01:02 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
ANOTHER PIC WHAT'S YOUR OPINION OF THIS PRODUCT????
MEMBER #6377
Project "7DEUCE"
Old 12-20-2003, 01:10 PM   #3
wildbill
theft prevention
French Blue,
Let me know how it works. I was thinking of putting one of those on my truck.
72 Chevy lwb 4x4
71 Blazer CST 4x4
wildbill is offline   Reply With Quote
Old 12-20-2003, 01:31 PM   #4
'72 Shorty
I finally got an avatar
'72 Shorty's Avatar
I had one of those. just hooked it up in line in the batt neg wire. It worked fine until I got the timing advanced too far and the amp draw of a stalled starter cooked it. I spend 2 days trying to figure out why the truck wouldn't start.
-72 C-10 short step (straight line only)
12.922/102.28
-69 C-20 on Propane (DD)
-69 C-10
-56 Mack B-753LS (tow rig)
-94 Chev K2500 Short Ex-Cab
-89 Isuzu Trooper...Kinda
-03 Kawasaki KFX-400
-05 Suzuki DRZ-400S
'72 Shorty is offline   Reply With Quote
Old 12-20-2003, 01:31 PM   #5
highboy_04
highboy_04's Avatar
cool, i've also seen people take one of those turn off valves and put the in the fuel line so they can get out and pop the hood and turn it off...it actually works pretty well because the vehicle will start but then turn off.
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 12-20-2003, 04:49 PM   #6
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
You could just run a switch on the distributor power wire. Mount it up under the dash so no one can see it. If anyone trys to steal it they will just spin the motor without it ever firing.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 12-20-2003, 09:28 PM   #7
Rooster's 67
Rooster's 67's Avatar
wHen I worked for GM when we installed the gm alarms there was a wire for a manual starter interupt that we splice into the accelerate button on the cruise and you had to press that while turning the key to the start button. Same idea could be used here, Pust a relay in the starter circuit and trigger it with something like the high beam switch, or the headlights(park position), or a secret switch hidden somewhere.
On my SWB I am wiring up the cruise control button to my starter cut out relay
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-20-2003, 09:42 PM   #8
junkyardjohn
junkyardjohn's Avatar
I JUST JUMPED THE NUETRAL SAFETY WIRE (PURPLE ONE), OR I SHOULD SAY I PUT A TOGGLE SWITCH IN LINE, & MOUNTED IT UP OUT OF SIGHT UNDER MY DASH. WORKS SO FAR. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 12-20-2003, 11:35 PM   #9
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
You could put a switch on your parking brake release in series with your ignition starter wire.. Just reach down and yank back on the handle as your crank your truck over, works, and to other people, it will look like a 'normal' movement, just like unlocking the parking brake everytime you go to drive your truck.
As for the huge amp battery kill switches above, I would stick it between the battery and the starter, instead of just on the neg battery cable. This way, only your starter wouldn't have power, so that you (if this applies) wouldn't lose your stereo presets or something like that.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
