Old 03-06-2021, 08:12 PM   #1
forestb
forestb's Avatar
Rochester Quadrajet bolt hole size
Does anyone know the size of the bolt that will fit in these holes? I tried the bolts that I have and none of them fit.
forestb is offline   Reply With Quote
Old 03-06-2021, 08:41 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Rochester Quadrajet bolt hole size
What's the number on your carb?
The older carbs I think that was #10 x 32 threads?
I can check tommorrow.
If it a late model it has metric threads.
84 Chevy K-20
Old 03-06-2021, 09:14 PM   #3
Troy Sr
Troy Sr's Avatar
Well I went out and grabbed the screw that goes in those holes and it's 12-28 UNF. They are c'sunk oval head screws. I even took a pic of the screw but I can't get it to upload.
Take Care
Troy
Troy Sr is offline   Reply With Quote
Old 03-06-2021, 09:35 PM   #4
forestb
forestb's Avatar
17080507
2801 DNR
What is UNF?
Don’t worry about the photos
Old 03-06-2021, 09:38 PM   #5
forestb
forestb's Avatar
Thank you guys
Old 03-06-2021, 11:18 PM   #6
Getter-Done
17080507
170 means 1976 and later.
4th digit (8) means {in the 80's}
5th digit means (0) 1980
6th digit is Califorina only
7th digit is Chevrolet
8th digit is an odd number example (1,3,5,7,9) so it's a manuel trans.
Link: https://www.chevyhardcore.com/tech-s...ication-guide/
(UNF stands for Unified Fine Thread)
Link to threads : https://journeymans-workshop.uk/unified.php
84 Chevy K-20
Old 03-07-2021, 12:28 AM   #7
forestb
forestb's Avatar
So does 1976 and later mean it is a late model? So does that mean it is metric?
Old 03-07-2021, 12:34 AM   #8
Getter-Done
I don't know for sure.
Your's looks like it would be standard screws.
The ones that are metric have those torxs screws ,
But I would check the other screws with a thread pitch gage.
Or with a standard screw just to be sure.
84 Chevy K-20
