Old 12-20-2003, 02:29 PM   #1
veltex
veltex's Avatar
hei help which one is one?
lost track of what I was doing, is the #1 on a hei cap the one right in line with the Vac advance? need to put new wires on , thanks
veltex is offline   Reply With Quote
Old 12-20-2003, 02:32 PM   #2
cduster
I think the rotor should point towards the #1 cylinder when you put the dist in.
Dan
cduster is offline   Reply With Quote
Old 12-20-2003, 02:37 PM   #3
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
I don't know for sure, but you can hand crank the engine until the timing mark lines up with the TDC mark on the timing cover. Your rotor should be at number one.
Cat Fuzz is offline   Reply With Quote
Old 12-20-2003, 03:35 PM   #4
Rooster's 67
Rooster's 67's Avatar
Turn the motor over to the TDC pointer, this willbe either #1 or #6 firing, you can assume that it is one if the rotor is pointing in the general direction of cyl 1 but it can be stab in any position.
Wire the terminal that the rotor is pointing at as one if it runs like crap or doesnt run it is 180 deg out use #6 as #1 and wire it from there
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 12-20-2003, 04:16 PM   #5
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Ah, heck. I'll just go look at mine. brb
Old 12-20-2003, 04:26 PM   #6
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Starting at the connector block, counting clockwise its the third one.
Old 12-20-2003, 04:46 PM   #7
Rooster's 67
it is all dependent on how the dist was stabbed.
Old 12-20-2003, 04:52 PM   #8
tom hand
CCRider
tom hand's Avatar
Rooster's 67 is correct...number one can be any terminal depending on how the distribitor was installed. Just remove the number one sparkplug and get someone to bump the starter while you hold your finger over the sparkplug hole...the compression will push your finger out when number one comes up...where every the rotor is pointing when this happens is number one
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 12-20-2003, 05:28 PM   #9
fast14
fast14's Avatar
Yep cuz mine is the first one past the terminal block going clockwise. Just get your rotor in the right place and go from there.
Just a little crazy
1970 chevy full size half ton, soon to be one ton running gear, 350 turbo, 205 case, 355c.i.
fast14 is offline   Reply With Quote
Old 12-20-2003, 06:02 PM   #10
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Well, there IS a correct position for number 1. I just remember going by the book when installing my dist. Put the number one cylinder at TDC then turn the oil pump shaft until it lines up with the exaust valve on number 5. Or was it the intake on 5? BAH!
Old 12-20-2003, 06:11 PM   #11
jamis
F.A.S.T. president
jamis's Avatar
there is no correct position, you can set it up any way you like. It will work any any position as long as your at TDC on #1 and the rotor is pointing toward the #1 wire on the cap.
But all the manuels say the factory set #1 on the distributor at 5 o'clock or pointing toward the #1 cly. If you want to follow factory placement.
jamis is offline   Reply With Quote
Old 12-20-2003, 06:27 PM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
First off, number 1 is where you make it.
But, from the factory, it was the second pole clockwise of the connector deal. How can I prove this you may ask?
Let me post a picture of something that most mechanics have never seen. It's a factory wire retainer for an HEI. It is usually thrown away when the original plug wires are changed.
Note the neat little terminal numbers on it
Old 12-20-2003, 09:17 PM   #13
Rooster's 67
Hey Tx Firefighters got one of them neat shop frisbee's,,,
Man them things will fly!!!!
