Window channel
Looking for window channel, what size? So, converted doors to single glass with no metal trim on glass, glass is 1/4”, appears i need 5/8 window channel to fit in metal channel, but what height? And type? Dont want it too tight or sloppy...
51 chevy truck, |
#2 | |
![]() Join Date: Mar 2007
Re: Window channel
You must have not kept my PM from several years ago where I revealed my source for my narrow window channel. I reached out to that contact before Covid and he was semi retired. I have scoured the net and even ordered some incorrect channel in my search for a source. I still have a scrap piece left from my last build. I have one more supplier I need to call to check the dimensions with. The pictures look the same. Once I validate this is the correct stuff, I will share my info. Thanks Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#3 | |
Re: Window channel
#4 | |
Re: Window channel
Marc
Re: Window channel
Someone shows the 3/4 wide for 1/4 inch glass channel but searching for it didn't bring it up the other day.
Experience on my buddy's truck showed that frameless laminated glass in a 47/50 can break pretty easily if someone slams the door though. When I stretch my doors I plan to have tempered glass made for the doors.
#6 | |
Re: Window channel
Did you get anywhere with your samples? I have a few coming from Steele Rubber. Hopefully one of them matches the old sample I have.. Marc
Re: Window channel
Found some universal at a shop, heave to see if he can order more
#8 | |
Re: Window channel
OK let me know if you can order more and I will let you know what I find out out with my samples. They should show up next week. Thanks Marc
