Old 03-11-2021, 01:13 PM   #1
61hawk
61hawk's Avatar
Firewall Insulation with Factory A/C
I've done several searches but have not found an answer to my question. I realize that there is not a reproduction firewall insulation pad for trucks with factory air. The issue I am reading is with the evaporator housing which mounts up next to the firewall. Would there be any issue with just cut that section off and only using the driver's side and transmission hump section?
61hawk is offline   Reply With Quote
Old 03-11-2021, 02:32 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Firewall Insulation with Factory A/C
It's up to you I guess. What issues are you referring to? You can still use a product like Flatline Barriers Insulation and Sound Dampening behind the AC unit can't you?
Old 03-11-2021, 03:51 PM   #3
61hawk
61hawk's Avatar
I'm doing FatMat but wanted to do something that was more heat insulation on top of it. Figured a regular firewall cover would look correct vs something that was shiny or looked like carpet padding. I don't remember what it looked like when I pulled the truck apart 14 years ago but have been reading that a non-A/C panel won't work in a factory A/C cab.
Old 03-11-2021, 04:23 PM   #4
The Rocknrod
Moderator
If your not using the old original cover i think the repops have sections you can cut out to make it work.
Old 03-12-2021, 10:24 AM   #5
LT1 Burb
LT1 Burb's Avatar
I used one of those with my factory AC truck.
LT1 Burb is offline   Reply With Quote
Old 03-12-2021, 11:00 AM   #6
61hawk
61hawk's Avatar
Did you trim it where I showed above or were you able to use the whole thing?
Old 03-12-2021, 03:49 PM   #7
LT1 Burb
LT1 Burb's Avatar
It was a few years ago but I think it is prepunched and you just remove what you don't need. The worst part of installing them is those plastic parts you have to push through the firewall. They are about 3 sizes bigger than the firewall holes.
Old 03-12-2021, 07:03 PM   #8
61hawk
61hawk's Avatar
Thanks, that's also what I've been reading. I think I'll go ahead and order the rubber pieces or run down and see if I can find some of the right sized Christmas tree connectors in the Help section.
