Old 12-20-2003, 06:01 PM   #1
jamis
F.A.S.T. president
jamis's Avatar
need part #
Anyone have a part # for front shocks when usung 2 1/2 drop springs. I dont need high $ shocks....just want to run some monroes or equivelent. I found the stock front shock size works for the rear with 5" drop springs.
jamis is offline   Reply With Quote
Old 12-22-2003, 03:16 AM   #2
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I noticed that a company called Spring Tech is selling some on ebay for around $109. Thats not a bad deal for 4 of them.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 12-24-2003, 05:05 AM   #3
doughby82
doughby82's Avatar
i just tried that search didnt come up with anything for our trucks.this may sound dumb,but say if you dropped the rear 4 inches then you would need to just find shock that are 4 inches shorter correct?im only askin so i can try searchin for some.thanks
springfield illinois
2003 custom (harley)built from scratch
68 swb
doughby82 is offline   Reply With Quote
Old 12-24-2003, 09:11 AM   #4
jamis
F.A.S.T. president
jamis's Avatar
yes you would need shorter shocks in the rear but only if you went as far as removing the original bump stops or c-notch. the same for the front if you used drop spings, but not if you ONLY used dropped spindles.
I emailed a few shock companys and so far monroe was the only one that got back to me. They did not have a cross refrence for what I wanted but they sent me a spec sheet with all there shocks. I forgot the info at work but I will post it as soon as I can.
They make some really nice performance shocks, but I just dont need to spend $200 + on them. For my type of driving, using plain gas shocks would be more then fine.
Thanks chevydog66, I will search ebay
Old 12-24-2003, 10:48 AM   #5
Izzy
Trucker.
Izzy's Avatar
http://www.macsspring.com/website/shocks-doetschtech-catalog-chevy-frame.htm
The part# for the front 2.5” DT shock is 4809G.
Izzy is offline   Reply With Quote
