Big window conversion
Those of you that have done it, how did you separate the top seam? I can see myself getting very irritated trying to blindly grind the spotwelds from the back side. Any tips or tricks? I do have a panel buster like this, but I’m afraid it may damage the edge I need to keep.
Moderator
![]() Join Date: Dec 2012
Re: Big window conversion
I haven't done a top, but I've drilled out lots of spots and separated panels. Drill out, air chisel/manual chisel/hammer. Straighten edge with hammer and dolly.
I’m very familiar with the practice, drilling this particular area isn't possible and why I’m asking about alternatives.
![]() Join Date: Feb 2014
When I did mine I used a cut off wheel and cut along side of the seam then I was able to get to the spot weld with a die grinder it still wasn’t real easy but doable put the new one back using panel bond
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
This ^^^^, cut panel as close as you can to seam, and then use die grinder, there is at least 30 spot welds. You want to minimize damage to front side as you will need to panel bond to it.
I got real lucky as my cab was assembled late on a Friday, I only had 10ish spot welds back there actually holding. Small amount of prying and it jumped right off.
I have the panel bond and the applicator, but have never used it before. Do I wipe off any excess that squeezes out with solvent? Thanks gentlemen. |
https://www.youtube.com/watch?v=tOWZWyB24LU
Here's a really good tutorial. The die grinder tip above is the way to go. Use a ball shaped tip. |
#8 | |
Better to use paint thinner because lacquer thinner might take paint off. And both surfaces must be clean dry metal for the panel bond.
