![]() Join Date: Feb 2009
WTB - looking for Vent Window Parts
FOUND WHAT I WAS LOOKING FOR. Didn't know that bar was part of the assembly unit. Thank you.
Discovered why my RH roll up window was so clumsy yesterday, getting T-boned will do that, took us five house to fit the door when the accident first discovered, bent pillar & that. Good news we feared the door was well plastered, but no, the guys did I nice job pulling out the dent, but they favored bondo over welds for the holes they drilled. Anyway the vent window is nice less a bent bar and bracket, loose rivets on the bracket. I straightened the bar to a major extent, enough to put the chrome edge back on. It's going in for a tune-up, - either way the bracket has to come off to finish straightening the bar, not a big deal. 1. I'd rather start with a good bracket, so looking for one of those for sure. 2. If it's out there, see the exterior chrome bezel in the picture. I think they're interchangeable left or right. Mine is real good, no pitting etc., better is better ![]() 3. Can be talked into the chrome edging for the felt if they're sharp. 4. Or just a vent window with nice parts described above. Thank you.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-15-2021 at 03:38 PM. |
![]() Join Date: Dec 2013
Re: WTB - looking for Vent Window Parts
truck shop .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
I Google it, but nothing comes up, any other help
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
![]() Join Date: Jan 2004
Always on the hunt...
![]() Join Date: Sep 2006
Hi Tony, we have a pair of NOS division bar felt channel runs available in the below linked "Several GM NOS 67-72 Truck Parts" f/s thread, listed as part/item #19. Have a look if interested in replacing the complete rear of vent wing channel. Mel
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=798288 . |
#6 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#7 | |
#8 | |
