Old 03-13-2021, 08:57 PM   #1
58CameoAZ
C4 Suspension ?
Hey Guys,
Anyone out there using a C4 front suspension using Flat Out Kit,
I am trying to hook up my steering to the column and am finding my
Rack conection Double D is not 3/4" ? What source did you use in hooking up
the universal joint and what size is this? 17mm ?
Hope this makes seance? and any Pics?
Thank you for your time,
Allen
58CameoAZ is offline   Reply With Quote
Old 03-14-2021, 07:32 PM   #2
Rickysnickers
Re: C4 Suspension ?
Thumb through here and I'll bet you can probably find something that will work for you.
https://www.borgeson.com/xcart/home.php?cat=2&page=1
Old 03-14-2021, 08:01 PM   #3
58CameoAZ
Re: C4 Suspension ?
Thank you Sir,
I was acutually looking threw there site when you posted!
I think i am limited to a 17mm x3/4" vibration reducer with the C4 corvette's shaft coming out of the Rack that i have ?
Thank you again!
Allen
Old 03-14-2021, 09:32 PM   #4
iceman4
Re: C4 Suspension ?
I bought mine from Summit. C4 rack is 17mm DD. Summit has several options for 17mm DD to 3/4" DD universals.
iceman4 is offline   Reply With Quote
Old 03-15-2021, 10:54 PM   #5
Kevin_C
Re: C4 Suspension ?
I got mine from summit as well 17mm - 3/4dd. I have some pics towards the end of my build thread
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 04-12-2021, 12:05 AM   #6
solidaxel
solidaxel's Avatar
Re: C4 Suspension ?
I used the shaft from the C4 and ground a DD on the end to the steering shaft
You have choices on the coupler DD to size of your steering shaft
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-13-2021, 11:55 AM   #7
dsraven
Re: C4 Suspension ?
be careful with the vibe reducers if you run any angle, they don't usually like too much off angle stuff and will come apart. they are more or less made to run straightline.
dsraven is online now   Reply With Quote
