Old 03-19-2021, 12:09 PM   #1
57FleetsideC4
Lifting a cab
Hi All, I am almost finished mocking up everything and will be taking it apart to sandblast and do body and paint. My question is taking the cab off. It will be bare no doors or glass. Could I pick it up at the bottom front inside edge of the step? I think I am safe with just in front of the rear body mount. I will be using my 2 post lift. Then I will try to attach my rotisserie to it. Thanks Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 03-19-2021, 01:48 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Lifting a cab
I had mine on and off the frame a couple hundred times using my 2 post lift..
A bare stripped cab is fairly lightweight
Even when it was sitting on the frame I could pick it up from the side by hand..
Mines not a TF but you should be fine
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-19-2021, 03:55 PM   #3
mr48chev
mr48chev's Avatar
Re: Lifting a cab
There are about as many ways to lift a cab as there are guys doing it
A two post probably gives you more and safer options than most of us have.
Probably a couple of heavy planks or 4x4s though the door openings with or without something to pad the tops of the door openings from the boards is what I'd do.
The way you are thinking should work just as good once I read it though for a second time.
My ongoing truck projects:
Old 03-19-2021, 06:31 PM   #4
57FleetsideC4
Re: Lifting a cab
Thanks for the input guys. I don't think I can crush the step when lifting it. It's all new metal. I am overthinking this. I just picked up a 67 442 body (which is heavier) on the rocker pinch welds and it didn't hurt anything. Thank Again Steve
Old 03-19-2021, 07:19 PM   #5
Black_Sheep
Black_Sheep's Avatar
Re: Lifting a cab
I made a T bar with a couple of 2x6's and some steel plate. Easy, it makes lifting the cab a one man job...
Black_Sheep is offline   Reply With Quote
Old 03-20-2021, 04:34 AM   #6
MiraclePieCo
MiraclePieCo's Avatar
Re: Lifting a cab
I did my pickup just like Black Sheep above. But lifting my panel truck body off was a lot more complicated!
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 03-20-2021, 09:01 AM   #7
57FleetsideC4
Re: Lifting a cab
The cherry picker method would not work for me. I need to slide the rotisserie bars where the picker would be. My 2 post lift is going to work and was just wondering how strong the front step area was. I am convinced it is strong enough to support the shell while connecting the rotisserie. Steve
Old 03-20-2021, 10:08 AM   #8
my56chevytruck
my56chevytruck's Avatar
Re: Lifting a cab
I've taken loads of pictures while working on my 56 but for what ever reason, nothing lifting the cab. I also have a 2 post ROTARY lift and used it to lift off the cab. it'll work just fine. I used my tow straps to wrap around the cab to the lift arms just to be safe. my .02 worth.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 03-20-2021, 09:24 PM   #9
_Ogre
_Ogre's Avatar
Re: Lifting a cab
4 guys and a six pack worked for me
shop air compressor timer
Old 03-21-2021, 01:53 AM   #10
Daze57
Daze57's Avatar
Re: Lifting a cab
ogre
your lucky sir i had to get the guys whiskey!! after a good lift of the cab ----came good lifts of the libation ------all good !!!
Daze57 is offline   Reply With Quote
Old 03-21-2021, 10:27 PM   #11
dsraven
Re: Lifting a cab
if you lift from the cab step area, behind the rocker lip, and support it with a length of 2x4 or something like that from front to rear it should be fine. that is assuming the steps, hinge pillars, step support bracket etc are all in good condition. watch for the step reinforcement bar that runs fore to aft on the under side of the step as lifting on that can deform the bar. lifting under the rocker can deform the rocker if not using some sort of weight distribution method like a long 2x4 to span the length.
Old 03-21-2021, 11:34 PM   #12
mick53
Re: Lifting a cab
When you get it mounted on the rotisserie can you post some pictures? I need to do it on my 53 and have never used mine.
mick53 is offline   Reply With Quote
Old 03-22-2021, 09:14 AM   #13
57FleetsideC4
Re: Lifting a cab
Thanks for your input. I have replaced the lower hinge area, floor sections, lower rear fender brkt, front lower filler behind the hinge area, cab step and inner and outer cab corners so should be solid enough. But unfortunately remembered why I wasn't using the 2 post in the first place. My 2 post is in my back shop which is used for storage and maintenance and also has a 10' door. Where I do my restoration work is another shop that only has a 7' door. I am going to be to high I think to mount it on the rotisserie and get it through the front shop 7' door. So got to figure something out. Steve
Old 03-22-2021, 09:17 AM   #14
57FleetsideC4
Re: Lifting a cab
I will post some pics once I get it mounted. My rotisserie has been used for 67-73 oldsmobile 442's and vista cruiser and had to make one mod. on the front mounts to work on this pickup. The good news is I will only be using 2 10' sections of square tubing instead of 4 which should be easier to move around. Steve
Old 03-22-2021, 06:34 PM   #15
mick53
Re: Lifting a cab
Thanks, I think I have 3 sets of mounts but have never used them. I also have extra tubing to make some.
Old 04-01-2021, 09:45 AM   #16
my56chevytruck
Re: Lifting a cab
I used my 2 post lift multiple times.
1940 Ford Dlx Coupe
1969 Mach1
