03-19-2021, 02:11 PM | #1 |
Throttle linkage 2 Barrel Carb
Truck - 67 c20 283ci in the i6 position.
The throttle linkage angle seem to me a little off. I just recently swapped the v8 in place of a i6. Will the i6 linkage work on a 2 bbl v8 set up? The See pictures below. sorry for the picture angle.. Thank you, Grant
67 C10 Fleetside SOLD 67 C10 SWB Fleetside 67 C20 Fleetside 68 C10 Fleetside 68 C20 Fleetside SOLD 72 k20 Pay Pal: Grant.Furneaux@gmail.com |
03-19-2021, 02:38 PM | #2 |
Re: Throttle linkage 2 Barrel Carb
That looks similar to my 68 327ci setup. I just switched to the throttle cable setup from a 71-72. If you need a spare I can post it in the parts board.
1968 GMC C2500 Long Bed Fleetside |
03-19-2021, 06:32 PM | #3 |
03-20-2021, 12:17 AM | #4 |
Can you switch the throttle linkage to the inside of the bracket in the rear?
Currently you have it on the outside position in the rear. |
03-20-2021, 05:37 AM | #5 |
You can also make an adapter plate, use the 2 pivot holes to attach, then add new holes in your adapter for throttle linkage. You can level out the rod better with a longer piece. Same process if you add an auto trans and need cable hook up like photo.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
03-20-2021, 08:15 AM | #6 |
Get rid of the "death linkage " and switch to cable .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
