12-20-2003, 10:38 PM | #1 |
question on rear suspension swap
I have a 84 1/2 ton suburban and am thinking of putting a set of 20 series rear leaf springs on my rear. I pull a lot of heavy trailers and it seems to ride too low in the rear for me.
1. What do I need to perform this? 2. Can I use my rear axle I have now, or do I also need to get the rear axle from a 20 series vehicle? Any help would be appreciated. Thanks Tommy Davis
junkyardpartseeker@sbcglobal.net |
12-21-2003, 12:11 AM | #2 |
Robert Olson Transport
I just did that on my 1976 i took leaves off a 20 series suburban and swapped them onto my C 10 pickup.
Its alot easier of the bed is off cause i used the shackles from the 3/4 ton springs. what i did is i used the U bolts off the 3/4 ton truck and the metal braces they used fromt he 3/4 ton too. youll have to bend down the bar where the rubber brake line sits so it dont pull it apart and i bought new shocks for the 3/4 ton truck and used them it rudes fine and gives ya several inches of lift in the rear
12-21-2003, 12:18 AM | #3 |
suspension
Ok, so I just need the springs and U bolts from a 3/4 ton. Not the rear axle.
And shocks rated for the 3/4 ton. Are the end eye holes the same distance apart, or each different. I have read other posts of ppl talking about the distance. Tommy
12-21-2003, 12:27 AM | #4 |
install air ride bags....they make a compressor kit too.
i have it on my truck....for hauling garage doors... i can raise and lower while driving....add air for more load and remove air for light loads..... they kick butt..... the whole kit cost about 350.00.... rides like a dream |
12-21-2003, 01:41 AM | #5 |
Right turn Clyde
I think your thinking about the difference between 3/4 and 1 ton. On the 1 ton rears the spring perches are in closer to the center chunk a little. Im thinking maybe about an inch but that's just a guesstament. The 1 tons are the frames are narrower. The 3/4 tons have the same spring perch locations as the 1/2 tons.
Not to have you spend more money or anything. But would it be better to get a 3/4 rear setup? I guess this will depend on the weight of the trailers. Im guessing you have a 10 bolt rear. I was thinking if this might be a weak link for hauling or not. Edit: I misread that question. On trucks there are two different spring lengths. One is 52in which was in a lot of 1/2 tons and 56in witch was heavier duty leafsprings that could be ordered on 1/2 tons. Im pretty sure that the 56in leafsprings are standard on 3/4 and 1 tons and optional on 1/2 tons. Suburbans might be different Im not sure.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI Last edited by MylilBowTie; 12-21-2003 at 01:48 AM. |
12-21-2003, 01:42 AM | #6 |
dang mark, you never mentioned that you bagged your truck before...
