Old 03-20-2021, 04:42 PM   #1
2112
Truck Dies after 15 minutes??
I have been having an issue with my 72 c10 with a 307 and 2 barrel carb. It will start up fine and run great until it gets up to temperature. After a few minutes it just shuts off. If I try to start it again the ignition is dead and acts like the battery is dead. After a few hours it will start right up no problems and shut off again after a few minutes. Seems like something is shutting down once it gets warm. Anyone have an idea as to what it could be? Thanks for the help!
1972 Chevy c10
1985 Buick Grand National
1951 Crosley
1941 Cadillac
2112 is offline   Reply With Quote
Old 03-20-2021, 05:36 PM   #2
Willys_MB
Willys_MB's Avatar
Re: Truck Dies after 15 minutes??
Could be vapor lock, but if you have an HEI when they’re going bad (not just the module) they mimic vapor lock issues. I’m sure more people will chime in with other possibilities, but if you have an HEI, pull it and check all the parameters.
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 03-20-2021, 05:47 PM   #3
landarts
landarts
Sounds like possible heat soak causing starter to not fire.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 03-20-2021, 05:49 PM   #4
Willys_MB
Willys_MB's Avatar
That’s a good point, I must have skipped the dead battery part on my first read through. That shouldn’t kill the engine, though, so it could be multiple issues happening at once.
Old 03-20-2021, 05:50 PM   #5
Sheepdip
Sheepdip's Avatar
Next time it does that make sure it is in park or neutral e-brake set then take a screw driver and jump the starter solenoid and see if it cranks over. Also check your starter solenoid connections to make sure they are all tight. If that's good go to your ignition switch and test it
With the dead battery issue it sounds like heat is causing a contact separation some where.
Sheepdip is offline   Reply With Quote
Old 03-20-2021, 09:55 PM   #6
2112
Thanks for the feedback guys. It does have HEI but I will check the starter first and work my way back to the ignition to see if I can find the problem.
1972 Chevy c10
1951 Crosley
1941 Cadillac
Old 03-20-2021, 10:17 PM   #7
BigBird05
When it dies and acts like a dead battery, Turn on the head lamps. If they come on then it sounds like it might be a ign switch problem. Start your diagnostics from there.
BigBird05 is offline   Reply With Quote
Old 03-21-2021, 01:57 AM   #8
franken
There are multiple odd issues. Start with one, probably the cranking (starter turning the engine), solve that, then move to the ignition, etc.
Saves brain cells
franken is offline   Reply With Quote
Old 03-21-2021, 11:15 AM   #9
Sheepdip
Sheepdip's Avatar
Does the HEI have a FULL 12 VOLTS to it?
Old 03-21-2021, 11:23 AM   #10
tjc
tjc's Avatar
are you using the Pertronix ignition?
Tom in Iowa
68 L88 C10
68 4x4 C10 soon
tjc is offline   Reply With Quote
Old 03-21-2021, 11:59 AM   #11
68 P.O.S.
What carb are you running? What's your timing set at?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 03-21-2021, 12:57 PM   #12
HO455
Post Whore
HO455's Avatar
When it dies there are some things to check.
Does it have spark? Check it with a plug grounded or a spark tester.
No spark. Check voltage to the distributor.
Good voltage. Then pull the coil from the cap and inspect the condition of the connectors. While there take ohm readings on the coil. But remember they may indicate good once the coil has cooled.
I would then inspect the interior of the distributor and if nothing stands out then would test the pickup coil. Disconect the coil and with an ohm meter check each lead to ground. Should be infinite resistance. Then check continuity between the leads it should not be zero but somewhere between zero and infinity. The hard part of this test is that once the coil has cooled it may test okay. The same thing with the HEI control module.
Some links that may help you. And like everything on the internet suspect.
https://www.chevyhardcore.com/news/h...-distributors/
https://www.jalopyjournal.com/forum/...module.706237/
If you have spark then check for fuel in the float bowl by winging the throttle while looking down the carburetor. You should see a stream of fuel being shot into the engine every time you wing the throttle. If not then you have a fuel supply problem.
If you have fuel and spark then it is time to look for a carburetor problem.
Good luck and keep us apprised of your results.
RIP Bob Parks.
Old 03-21-2021, 07:14 PM   #13
toolboxchev
I am suspect too the distributor also, HEI yup. Ignition Module or Coil, yup.
No way that I am aware of to test the module other than a "No Spark Issue" under the heated condition. The article listed below says the auto parts store can test a module but I highly doubt it considering the ways of todays world. Use a known good unit.
Coil on the other hand can go bad and testable very easily. I had an Accel unit that was only about 50 ohms out of spec and it was doing all kinds of stupid crap.
Use this:http://www.crankshaftcoalition.com/w...or&redirect=no
Let us know what you find out. Diagnosis the proper way is always least costly instead of throwing parts at it.
toolboxchev is offline   Reply With Quote
