Old 12-20-2003, 11:33 PM   #1
1971 2wd
Unhappy Dumb lift Question
Will a 8 inch lift from a 73-87 chevy fit on a 72 Blazer??
Are springs the same?
The steering components are different, correct??
Like the title say's " Dumb lift Question"
Thanks for any info!!
72 blazer, 71 2wd short bed, 67 nova
Too many damn toys!!
1971 2wd is offline   Reply With Quote
Old 12-20-2003, 11:42 PM   #2
714x4lover
DUMB ? ALRIGHT
THE SPRINGS FROM 73 AND UP ARE LONGER THAN THAT OF THE 67 TO 72 ALSO THE STEERING PARTS ARE DIFFERANT , OUT OF CURIOUSITY DO YOU HAVE A PITMAN ARM YOUD SELL ( PITMAN ARM IS THE PART THAT HOOKS TO THE POWER STEERING BOX.
714x4lover is offline   Reply With Quote
Old 12-21-2003, 01:45 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Lonn, You need a stock power steering pitman arm? I have mine off my 70. Replaced it with a 2" DROP Skyacker pitman arm.
As far as the 72 K5 steering you can get a rasied steering arm and dropped pitman arm which are the same as 73 and up. Now the 67-68 trucks have different steering. Like Lonn said the springs are different in front but not the rear unless you have the 56" long rear springs. 67-68 rear springs are completely different.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-21-2003, 03:29 AM   #4
714x4lover
PITMAN ARM
JIM IM IN NEED OF A PITMAN ARM THAT WILL ACCOMIDATE A 4" RANCHO LIFT , PLUS IM THINKING OF PUTTING A 2'' BODY OR SHAKLE LIFT .HAVNT DECIDED YET WITCH WAY TO GO.
Old 12-21-2003, 11:00 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Lonn, I think you'd be better off with a raised steering arm, it bolts to the knuckle and is good for 4"-6" of lift. It would also be the cheapest. I paid $85 for my 2" pitman arm. A steering arm goes for about $50-60. 2-4" lift drag links (connect pitman arm to steering arm) is abouy $120.
I thought maybe you needed a stock pitman arm.
Old 12-22-2003, 12:05 AM   #6
714x4lover
steering arm
is the steering arm the u shaped thingy that connects to the caliper area, drag link is the adjustable tie rod looking thing. i know what the pitman arm is. soi dont need a pitman arm.
Old 12-22-2003, 12:50 AM   #7
Destructo
Yes the steering arm is the U-shaped thing and has 3 holes in it. Drag link is the adjustable rod that connects pitman arm and steering arm together.
Destructo is offline   Reply With Quote
