12-20-2003, 11:50 PM | #1 |
It's a catastrophic success.
6v to 12v swap
I swapped a 6volt sys to 12 volt and everything went fine until when you would turn the key off the alternator was back feeding the ignition and not shutting off.
I went to the search and found that I need a resister on the #1 or switched wire. my Question is if I walk into auto zone and request this will they have a clue what Im talking about, It wasnt easy getting the other stuff(coils,ign resisters,relays,sol) Is there a part # to ask for so they can see it on their computor or they wont have a clue. Thanks |
12-21-2003, 12:10 AM | #2 |
My son, my joy.
If Autozone is anything like Schucks, they will just get an annoyed look on their face and then make a lame attempt to look like they are trying to find what you want, and then tell you to go to the dealer or a wrecking yard.
12-21-2003, 12:12 AM | #3 |
My son, my joy.
I really get annoyed when they have to look up valve cover gaskets for a SBC. I used to know all the gasket numbers for SBC's by memory.
12-21-2003, 12:15 AM | #4 |
i have this same problem. it wont shut off.what kidna resistor??
70 longbed 496/th400/Ford 9" |
12-21-2003, 12:25 AM | #5 |
dinnut,
this is what I found in search.
http://www.autorewire.com/tech/charg...10SInandd.html |
12-21-2003, 01:17 AM | #6 |
www.speedwaymotors.com part#910-64100
12-21-2003, 01:18 AM | #7 |
Captain CAAAVVVMMMAAANNN!
get a diode trio out of a internal regulated alternator and use that in the line in question, you only need one of the 3 leads off the diode trio, so if it burns out you have 2 more to use. just make sure it is in the prober direction with the flow or it will work backwards.
you should be able to ask for a diode trio for amid 80's gm alt. and get it w/o much trouble...
72 LWB Fleetside C10 Custom 350/350 97 GMC Yukon 4X4 SLT Anna, Texas check out the project old yeller |
