Old 04-01-2021, 09:40 PM   #1
chevy49
chevy49's Avatar
20 inch wheels and tires
I have a 65 short fleet truck with the small rear notch and strong arms on front with all corners air bags what 20 inch wheels and tires will fit and still be able to get them off without lots of work? Thanks
chevy49 is offline   Reply With Quote
Old 04-02-2021, 09:30 AM   #2
SCOTI
SCOTI's Avatar
Re: 20 inch wheels and tires
Lowered 6x-66 fleet-side's require more work (some would consider it lots of work) to get the rear wheels/tires off because of the fender well opening. Having enough clearance to pull the wheel from the hub so it clears & can be maneuvered out is a plus. The wider the wheel set-up, the more work it usually is for install/removal.
Lighter alum/billet wheel vs steel would require less effort as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
