04-02-2021, 03:48 AM | #1 |
How do I fix cracked metal door panel?
Found this cracked metal around the window regulator, after removing door panel to fix door latch. I could just close it up and pretend I never saw it...but that’s not my style! It does not affect window crank operation “yet” but it looks like it will just get worse. Any ideas how to fix it? Or vote to just leave it alone?
This is my ‘64 C10 fleetside
-Pickman (Mike) 1964 C10 Fleetside LWB “George” 1963 C50 “Green Machine” 2019 Silverado 2500HD My story (Welcome Page) Last edited by Pick121; 04-02-2021 at 03:50 AM. Reason: Forgot vehicle |
04-02-2021, 06:08 AM | #2 |
Moderator
Re: How do I fix cracked metal door panel?
Cut the damaged section out and weld a new one (or undamaged) in.
04-02-2021, 10:24 AM | #3 |
2nd that on cut and patch. If this is a fix for down the road, drill a hole at the end of each crack line to help prevent them from spreading further. Drilling isn't the cure, it just stops their growth for a bit.
My truck ain't dead, it just smells funny. |
04-02-2021, 10:53 AM | #4 |
Makes you wonder what the story is behind those cracks. They're stress cracks, but how were they caused? Was the window that hard to open and close that over years it finally cracked? Were the screws loose which caused flexing of the metal in that area over a long period of time?
Since it's covered up I'd weld it up, put the cover back over the door and forget about it. If I were doing a full restoration I'd cut it out and replace it. |
04-02-2021, 12:11 PM | #5 |
My '61 had cracks at the window guide mounting holes at the back jamb of the door. Cut 'em and patch em and move on
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
04-02-2021, 12:51 PM | #6 |
I looks to me like you've got a rust problem that has gotten so thin that the normal window cranking pressure has caused it to crack through. you might be chasing a bigger problem. If you could find a donor piece that you can patch in would, in my opinion, be the best wat to go unless you're an excellent metal worker.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
04-02-2021, 12:55 PM | #7 |
I would disagree - they look like fatigue cracks to me.
Had them at the West Coast Mirror mounts, the window guide mounts, and the window crank mounts on one door. I'll bet the later trucks have either larger fasteners or thicker reinforcements.
04-02-2021, 01:04 PM | #8 |
That hole beneath the bottom screw should not be there. If I had a scrap door, I'd cut that section out and send it to ya, but unfortunately, I don't have a scrap door
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-03-2021, 06:37 PM | #9 |
Or create a plate that fits inside the recessed part of the door, drill a couple of holes then weld the plate to the door. New support carried on either side of the cracked area.
04-03-2021, 07:01 PM | #10 |
For a "gitterdone" kind of fix...maybe weld some appropriately sized washers on there.
04-03-2021, 07:32 PM | #11 |
Lot of Great Idea's above
I will add, Which ever route you choose, When welding like that It is best to use some type of copper backing plate or spoon. Here is a video to explain more. Link: https://www.youtube.com/watch?v=PAKH0QAfv_A .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
04-03-2021, 11:41 PM | #12 |
I'd just weld up the cracks and butt weld a patch in for the missing bit. Maybe anneal the area afterward.
Check it in 20 years to make sure it's still ok... |
04-05-2021, 12:35 AM | #13 |
Thanks for all the reply’s friends, lots of great ideas & input. I will probably go with welding in a patch. It is a daily driver not a show truck. It seems like a real fragile area to weld between the bolt holes and with a chunk of metal completely missing. Also some of the other ideas I am concerned how it will affect the alignment/operation of the window regulator. As this is my first try at welding in my 57 years on this rock I am glad it will be hidden behind the door panel when it’s done!
I agree about the stress crack as cause, the window “does” roll up & down but it is takes some muscle, not smooth like butter that’s for sure - and no major body rot inside the door panel. The reason I found it is because this is one of those trucks that whenever I shut the door, to get out I had to roll down the window to open the door with outside door handle (inside door handle did not work the latch). Which is why I am replacing the latch. Been this way since I got it and finally got tired of rolling the window down and then up again to get out! So, thanks again for all the advice
-Pickman (Mike) 1964 C10 Fleetside LWB “George” 1963 C50 “Green Machine” 2019 Silverado 2500HD My story (Welcome Page) |
04-05-2021, 01:18 AM | #14 |
Have you sprayed that coil spring really well with something like PB blaster? Spray it and keep running the window up and down, spray it again and repeat....and just keep doing it while you watch the rusty crap roll outta there and run down the door. It will smooth things out.
04-05-2021, 05:01 AM | #15 |
On my door with the most cracks, the spring was broken.
