Old 04-03-2021, 06:19 PM   #1
slepysal
slepysal's Avatar
interior redo
I decided to change out my carpet, I almost went with red but decided to stick with black. I used some kilmat (25 Sgft) . Done for today will wrap it up later.
Name:  km install.jpg
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-03-2021, 07:00 PM   #2
kens65fb
Re: interior redo
Looks nice !!!
kens65fb is offline   Reply With Quote
Old 04-03-2021, 07:07 PM   #3
AcampoDave
AcampoDave's Avatar
Re: interior redo
I use Kilmat too. The price is right and the reviews are very favorable. Also, unlike other bargain deadeners it's not asphalt based.
AcampoDave is offline   Reply With Quote
Old 04-03-2021, 07:10 PM   #4
kens65fb
Re: interior redo
I looked at Kilmat, it said that is a butyl compound, isn't butyl asphalt based?
Old 04-03-2021, 10:35 PM   #5
slepysal
slepysal's Avatar
Re: interior redo
Butyl rubber, sometimes just called "butyl", is a synthetic rubber, a copolymer of isobutylene with isoprene. The abbreviation IIR stands for isobutylene isoprene rubber.
kilmat is inexpensive and very easy to install
Old 04-03-2021, 11:59 PM   #6
AcampoDave
AcampoDave's Avatar
Re: interior redo
I chose kilmat after I read this article... https://soundproofguide.com/fatmat-v...co-vs-dynamat/
Old 04-04-2021, 11:48 PM   #7
slepysal
slepysal's Avatar
Re: interior redo
Looks nice !!!
Thanks!!!
Old 04-05-2021, 12:29 AM   #8
62bagger
62bagger's Avatar
Re: interior redo
Looks good.
62bagger is offline   Reply With Quote
Old 04-05-2021, 11:14 PM   #9
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Re: interior redo
Looks Good Sal, is that 25 square feet Laid Down?? ..
GC66
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 04-06-2021, 09:40 PM   #10
slepysal
slepysal's Avatar
Re: interior redo
GC66
No I had two sheets left over 18x16 inches each that I plan on installing in the doors.
Old 04-07-2021, 07:57 AM   #11
kens65fb
Re: interior redo
GC66
So do you think that 25 SQ ft. would cover the entire floor and firewall?
Old 04-07-2021, 11:16 AM   #12
61hawk
61hawk's Avatar
Re: interior redo
Doubtful, 20 square feet is 5 x 4. I just did my truck in FatMat and it took 7.5 square feet to do each door. I used the rest of a 50 sq.ft. roll to do the back panel floor and firewall. I had to use about 15 sq.ft. from a 2nd roll.
61hawk is offline   Reply With Quote
Old 04-07-2021, 11:33 PM   #13
slepysal
slepysal's Avatar
Re: interior redo
If you are not going to do the doors , yes . As you can see there is a few spots I did not cover but I could have with the two pieces that i saved for the doors.
So before anyone chimes in with you should have done the complete floor I chose to leave the trans hump bolts exposed in case I need to remove it some day. I am not doing the whole doors just a single mat in the middle of it.
I am not planning to install a high end stereo system and after all these years of owning it the rattles don't bug me....
