F.A.S.T. president
![]() Join Date: Sep 2003
alternate postion for sway bar
when I ordered the new brackets for my sway bar, I forgot to order the custom ones that are shorter then the stock ones for dropped suspensions. But after looking at the brackets and frame I noticed you can run the bar between the bracket and frame instead of underneath. This sets the bar in the same location as with the custom bracket. This may not work with the poly bushings because they are thicker but works fine with the stock ones. Hopefully this will save someone some time cutting off the old ones if they are already there and money if they need new ones.
Very observent. I didn't even use brackets but that is a slick idea.
5-7 dropped 87 CC Dually
Seems to me that you could even cut the poly ones down to fit too. Very slick!
I rather be in my 77 Sanger Picklefork Jet Hydro! |
#4 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: alternate postion for sway bar
The bar is bent on the ends, it won't slide through.
That's a great idea. Good eye!
1968 Chev SWB with 1998 Corvette LS1 305hp and 320 ftlb to the wheels (stock engine!) AEM EMS and wideband O2 sensors Bowtie Overdrive's 700R4, stage 3 Baer 4 wheel discs and 20s http://iciclelanding.com/aperture?album=2049&view=album |
Out of the carpool lane.
I've got my brackets just bolted to the frame.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#7 | |
F.A.S.T. president
Re: Re: alternate postion for sway bar
aw man!i need to check out all sections of this board more often.i just ordered my brackets this morning.oh well
springfield illinois 2003 custom (harley)built from scratch 68 swb |
Thanks.......you just saved me some cash!
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
